是德科技
直播中
李诗晴
7年用户 156经验值
私信 关注
[问答]
E4980A带16451B电介质常数随间隙增加
我有一个带有16451B附件的E4980A LCR仪表,用于测试材料的介电常数。
我用它来表征一些聚合物,但是通过简单地测量空气的介电常数来进行一些理智检查,只是为了确认一切都井然有序。
然而,我发现我得到了意想不到的结果。
基本上,对于所有间隙,介电常数应该是常数1,但测量值告诉我它随间隙增加。
这在附图中显示。
关于要看的事情的任何建议?
我执行了一个简短的修正,但这只是一个偏移。
我有点困惑,因为如果它只是一个偏移,那不是一个大问题,但我担心的是,测量结果告诉我空气的介电常数会随着间隙而变化。
我仔细阅读了手册,看到第3-61页有一张表可以用来进行区域校正,但与我看到的问题相比,这种校正相对较小。
我很感激任何建议。
以上来自于谷歌翻译
     以下为原文
  I have a E4980A LCR meter with a 16451B attachment for testing the dielectric constant of materials. I am using it to characterize some polymers, but have performed some sanity-check by simply measuring the permittivity of air, just to confirm everything is in order. I am finding, however, that I am getting unexpected results. Basically, the permittivity should be a constant 1 for all gaps, but the measurements are telling me that it increases with gap. This is shown in the attached plot.
Any suggestions on things to look at? I perform a short correction, but this is just an offset. I'm a little perplexed because if it were simply an offset, that isn't as big a concern, but I am concerned by the fact that the measurements tell me the permittivity of air would be changing with gap. I've looked through the manual and see that there is a table on page 3-61 that can be used to make area corrections, but this correction is relatively small compared to the issue I am seeing.
I appreciate any suggestions.
附件
回帖(1)
周菊
2019-2-26 12:42:15
这绝对不是和示波器问题,但我不知道它属于哪里。
您应该致电当地的技术呼叫中心。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
     以下为原文
  This is definitely NOT and oscilloscope question, but I don't know where it does belong. You should call your local Technical Call Center.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
举报
更多回帖
