是德科技
直播中
杨兰兰
8年用户 221经验值
私信 关注
[问答]
在MultiTone界面中缺少完成的SCPI
在PSG 8267D的multiTone界面中,我注意到在相位噪声及其种子可以设置为Random之前需要按下“DONE”。
但是,我在SCPI参考手册中找不到这个“DONE”命令的SCPI。
以上来自于谷歌翻译
     以下为原文
  In the multiTone interface for PSG 8267D, I notice that "DONE" need to be pressed before the phase noise and its seed can be set to Random. However, I could not find the SCPI for this "DONE" command in the SCPI reference manual.
回帖(1)
吴键洪
2019-2-22 15:12:51
嗨,关于类似于DONE的scpi命令,不需要它,因为如果你从Initialized Menu软键发送SCPI,它就已经完成了。
例如。
发送: - :: RADio:MTONe:ARB:SETup:TABLe:PHASe:INITialize Rand comamnd将会发生。
你可以尝试一下。
谢谢,Petrina Yong
以上来自于谷歌翻译
     以下为原文
  Hi,
About the scpi command which is similar to DONE, it's not required since if you are sending the SCPI from the Initialized Menu softkeys, it will be already completed.
Eg. send:- ::RADio:MTONe:ARB:SETup:TABLe:PHASe:INITialize Rand
The comamnd would had taken place.  You can try it out.
Thanks,
Petrina Yong
举报
更多回帖
