你究竟想做什么,你是否担心决议?
这是一种低成本的信号发生器。
还有更多的错误来源会导致您比步骤解决更麻烦。
幅度精度为+/- 2%,仅在1KHz时指定。
DC模式下的DC精度为+/- 1.5%+ / - 3mV。
也就是说,大多数示波器衰减器使用1-2-5步进。
不能保证这里使用的是什么,但如果是,那么最坏的情况可能是最佳情况的2.5倍。
请注意,即使您知道步长,也无法明确知道DAC切换衰减的位置。
我通过考虑具体案例获得了2.5倍的数字。
例如,如果你假设DAC使用全范围来获得200mV,你想要201 mV,那么它将切换到下一个范围500mV,并使用40.2%的DAC范围来获得201 mV(非常接近)
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
Exactly what are your trying to do, that you are that concerned about the resolution?
This is a low-cost signal generator. There are many more sources of error that will cause you more trouble than the step resolution. The amplitude accuracy is +/- 2%, and only specified at 1KHz. The DC accuracy in DC mode is +/- 1.5% +/- 3mV.
That said, most scope attenuators use 1-2-5 stepping. There is no guarantee that's what's being used here, but if it is, then the worst case could be as much as 2.5x the best case. Note that there is no way to know, definitively, where the DAC switches attenuation, even if you know the step size.
I got the 2.5X number by considering a specific case. If you assume, for instance, that the DAC uses full range to get 200mV, and you want 201 mV, then it will switch to the next range, 500mV, and use 40.2% of the DAC range to get 201 mV (very approximately).
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
你究竟想做什么,你是否担心决议?
这是一种低成本的信号发生器。
以上来自于谷歌翻译
以下为原文
Al
举报
