由于占空比是在一个小时内测量的,所以我不这么认为,在模块和芯片手册中找不到任何东西。你必须在软件的更高层次上解决这个问题。确保你不经常发送超过0.1%的时间。下列限制:一小时内的总时间:一次传输的最大时间为3.6秒(0.1%):两次传输之间0.72秒的最小关断时间:0.72秒。/ Ruben
以上来自于百度翻译
以下为原文
Since the duty cycle is measured over a one hour period, I don't think so and could not find anything about that in the module and chip manual.
You have to solve this at a higher level in your software. Make sure you don't send more often than 0.1% of the time. The following limitations apply:
Total on time within one hour: 3.6 seconds (0.1%)
Maximum on time for one transmission: 0.72 seconds
Minimum off time between two transmissions: 0.72 seconds.
/Ruben
以上来自于百度翻译
以下为原文
/Ruben
举报
