是德科技
直播中
王玉珍
8年用户 168经验值
私信 关注
[问答]
emds_mesher.exe崩溃了
您好,我是该软件的新手,并尝试运行模拟并将其与教科书中的内容进行匹配。
我能够模拟偶极天线,现在我在圆环天线上。
当我运行模拟时,第一阶段大约需要15-20分钟,之后外部窗口无响应并被Windows关闭。
它通常发生在“面部分裂”和“刻面体”之间。
在日志中,错误是“保存SAT文件期间致命故障design_comb_result.sat:7015,errmsg =访问冲突”。
我试图以管理员身份运行软件,这没有帮助。
我很可能做错了什么。
这就是我的循环循环设计:http://img29.imageshack.us/img29/7708/genn.png!
我使用50Ω电压源,两侧之间的距离是任意的。
我使用x64版本的EMpro 2011.07谢谢你编辑:rad于2013年11月11日下午4:41
以上来自于谷歌翻译
     以下为原文
  Hello,
I'm new to the software and trying to run simulations and match them with what's in the textbook. I was able to simulate a dipole antenna, now I'm on circular loop antenna.
When I run a simulation, the first phase takes about 15-20 minutes after which the external window becomes unresponsive and is closed by Windows. It usually happens between "face splitting" and "faceting body" steps.
In the log, the error is "Fatal failure during saving of SAT file design_comb_result.sat : 7015, errmsg = Access violation". I tried to run software as admin, which didn't help.
It's quite possible that I'm doing something wrong. This is what my design looks like for circular loop:
!http://img29.imageshack.us/img29/7708/genn.png!
I used 50 Ω voltage source and the distance between the sides is arbitrary.
I use x64 version of EMpro 2011.07
Thank you
Edited by: rad on Nov 11, 2013 4:41 PM
回帖(1)
鄢蓉
2019-1-10 15:56:58
我猜你使用了“导入的”CAD几何体。
基本上导入的CAD模型不干净,这意味着它可能有一些间隙或细长。
请重新绘制模型。
以上来自于谷歌翻译
     以下为原文
  I guess you used "imported" CAD geometry. Basically the imported CAD model is not clean, meaning that it may have some gaps or slivers. Please re-draw the model.
举报
更多回帖
