大家好,我在使用不同的网格参数值模拟ADS EMDS(FEM)的简单结构时遇到了一致性问题。
因此,我无法决定适当的尺寸,继续制造。 我创建了一个57.002欧姆特性阻抗的四分之一波阻抗变换器。 它通过使用64.98456008-Ohms的负载电阻进行测试,因为该阻抗由阻抗变压器转换为50欧姆。 仿真设置和结果在附件中给出。 总之,我发现EM电路协同仿真存在两个主要问题,使用EMDS(FEM)和ADS-2008:1。对于微带线的相同尺寸,用于实现变压器,匹配频率随着变化而变化 FEM设置(“需要Delta错误的连续迭代”和“网格播种”的编号)。 2.随着微带线长度的增加,匹配频率的变化表现出不合逻辑的行为。 我的意思是逻辑上匹配频率应该减少,但事实并非如此。 请允许任何人在这方面帮助我或指导我找相应的专家。 这严重制止了我的工作。 顺便说一句,我可能还想知道是否在EMDS中进行了任何修改,因为ADS版本从2008年变为2009年再到当前的2011年? 提前致谢! Vivs 以上来自于谷歌翻译 以下为原文 Hello Everyone, I am facing consistency issues while simulating a simple structure with ADS EMDS (FEM), using different mesh parameters' values. Thus, I am not able to decide on proper dimensions, to go ahead for fabrication. I created a quarter-wave impedance transformer of 57.002-Ohms characteristic impedance. It is tested by using a load resistance of 64.98456008-Ohms, as this impedance is converted by the impedance transformer into 50-Ohms. Simulation set-up and results are given in the attached file. In sum, I found two main issues with the EM-circuit co-simulation, done using EMDS (FEM) and ADS-2008: 1. For same dimensions of the microstrip line, used to implement the transformer, matching frequency varied with change in FEM settings (no. of 'Consecutive Iterations of Delta Error Required' and 'Mesh Seeding'). 2. As length of the microstrip line is increased, change in the matching frequency shows illogical behavior. I mean logically the matching frequency should decrease, but it does not. May anyone please help me out in this regard OR direct me to the appropriate expert. This has severely halted my work. By the way, I may also wish to know if any modifications are also done in EMDS, as ADS version changed from 2008 to 2009 and then to current 2011? Thanks in Advance! Vivs |
1个回答
我很感谢安捷伦科技公司的应用顾问Anurag Bhargava(http://abhargava.wordpress.com/)。
他指出了在电路中使用“内部”端口的问题。 该端口未校准,包含感应寄生效应。 这导致了不一致的结果。 将端口2确保为“单一模式”可以缓解问题并导致一致的结果。 以上来自于谷歌翻译 以下为原文 I am thankful unto Anurag Bhargava, Applications Consultant at Agilent Technologies (http://abhargava.wordpress.com/). He pin-pointed the issue with use of 'internal' port in the circuit. This port being uncalibrated, contains inductive parasitics. This led to inconsistent results. Ensuring port 2 as 'Single Mode' has mitigated the problem and is leading to consistent results. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 22:58 , Processed in 1.053077 second(s), Total 67, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
