你好@ maganuru,
我相信这与XCZU9EG-ES1部分有关?
如果是这样,即使您没有在2016.2中添加此板,您是否可以在“部件”部分下看到并找到XCZU9EG-ES1 / EVAL设备?
如果没有,即使您设置了init.tcl,也需要有效的EA / ES许可证才能在Vivado中启用此功能。
您能否确认您拥有有效的许可证并且在此机器上设置正确?
Vivado可能无法检测到有效的EA / ES许可证,如果没有它,2016年无法为您启用所需的ES / Eval设备。
你能确认吗?
谢谢。
问候,
阿纳托利
亲切的问候,Anatoli Curran,Xilinx技术支持-----------------------------------------
--------------------------------不要忘记回复,工作,并接受解决方案.----
以上来自于谷歌翻译
以下为原文
Hello @maganuru,
I believe this is in relation to the XCZU9EG-ES1 part? If so, even if you don't have this board added in 2016.2, can you actually see and find XCZU9EG-ES1/EVAL devices under the "Parts" section?
If not, even if you have your init.tcl set, you'd also need a valid EA/ES license to get this enabled in Vivado. Can you please confirm that you do have a valid license and also it is set correctly on this machine? There could be possibility that Vivado can't detect a valid EA/ES license and without it, the required ES/Eval device can't be enabled for you in 2016.2. Can you confirm on this please? Thanks.
Regards,
Anatoli
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Don’t forget to reply, kudo, and accept as solution.
你好@ maganuru,
你能确认吗?
谢谢。
问候,
阿纳托利
以上来自于谷歌翻译
以下为原文
Hello @maganuru,
Regards,
Anatoli
Kind Regards,
Anatoli Curran,
举报
