赛灵思
直播中
蒋喜玲
8年用户 170经验值
私信 关注
[问答]
Xilinx 14.7使用zybo板出现错误
我正在使用xilinx 14.7作为我的项目。
合成verilog代码并为zybo board编写ucf文件格式后,我发现错误如ERROR:安全:9c  - 没有'ISE'也没有'WebPack'功能版本2013.10可用而且ERROR:Map:258  - 遇到了一个问题,试图获得
此架构的许可证。
我该怎么办...... plzzzz回复.....
以上来自于谷歌翻译
以下为原文
I am using xilinx 14.7 for my project. After synthesis of verilog code and writing ucf file format for zybo board, I found error like ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available and ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture. What should I do......plzzzz reply.....
回帖(13)
赵雪培
2018-12-24 14:10:36
SAYO @ 14,
您是否拥有ISE的有效许可证?
你可以共享运行Xinfo System Checker后应该生成的xinfo.txt文件吗?
同时查看类似的论坛帖子:
https://forums.xilinx.com/t5/Installation-and-Licensing/ISE-ERROR-Security-9c-No-ISE-nor-WebPack-feature-was-available/td-p/568756
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
sayo@14,
Do you have a valid license for ISE?
Can you share the xinfo.txt file which should be generated after running Xinfo System Checker
Also check the similar forum thread:
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
---------------------------------------------------------------------------------------------View solution in original post
举报
陈衡毅
2018-12-24 14:20:47
嗨sayo @ 14
您似乎没有相应的许可证和/或您所拥有的许可证不支持您正在使用的设备。
请在此附上许可文件。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi sayo@14
Looks like you dont have the corresponding license and/or the license you have doesnt support the device you are working with.
Please attach the license file here.
Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
赵雪培
2018-12-24 14:35:41
SAYO @ 14,
您是否拥有ISE的有效许可证?
同时查看类似的论坛帖子:
--Syed
以上来自于谷歌翻译
以下为原文
sayo@14,
--Syed
举报
郭佳
2018-12-24 14:52:02
Pinfo的xinfo.txt和license.lic文件......
问候,
小夜
xinfo 1 KB
xinfo 1 KB
license.lic 21 KB
以上来自于谷歌翻译
以下为原文
hi,
PFA of xinfo.txt and license.lic file...
Regards,
Sayo
            xinfo ‏1 KB                xinfo ‏1 KB                license.lic ‏21 KB
举报
更多回帖
