赛灵思
直播中
贾永世
8年用户 1901经验值
私信 关注
[问答]
axi 1g/2.5g以太网子系统实例限制评估许可证?
冰雹玛丽在这里。
我知道评估许可证有时间限制 - 但是有任何实例限制吗?
我无法在VC707板上同时工作两个实例(一个SFP,在一个SGMII上)。
SGMII内核具有包含在内核中的共享逻辑,而SFP模块没有并从前者接收其时钟。
然而,由于ISR停留在0x00,它似乎永远不会出现重置。
寻找鬼魂......
以上来自于谷歌翻译
以下为原文
Hail mary here. I know there is a time limit on the evaluation license- but is there any sort of instance limit? I cannot get two instances ( one SFP, on one SGMII ) working at the same time one the VC707 board. The SGMII core has shared logic included in core while the SFP module does not and recieves its clocking from the former. However it never seems to come out of reset as the ISR is stuck at 0x00. Looking for ghosts...
回帖(2)
刘溪
2018-12-21 11:06:57
你好
硬件评估许可证没有实例限制
问候,萨蒂什-----------------------------------------------
--- --------------------------------------------请注意
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.--
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi
There is no instances limit with the Hardware evaluation license
Regards,
Satish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
--------------------------------------------------​-------------------------------------------View solution in original post
举报
刘溪
2018-12-21 11:25:57
你好
硬件评估许可证没有实例限制
以上来自于谷歌翻译
以下为原文
Hi
Regards,
Satish
举报
更多回帖
