赛灵思
直播中
邹昀
8年用户 140经验值
私信 关注
[问答]
怎么续订AC701许可证
我的AC701的Vivado许可证版本限制为~2014.5。
有没有更新此许可证,以便我可以使用最新版本的Vivado?
以上来自于谷歌翻译
以下为原文
My Vivado license for my AC701 is version limited to ~2014.5.  Is there anyway to renew this license so that I can use the latest version of Vivado?
回帖(6)
姜雨孜
2018-12-20 11:25:10
您可以使用免费的WebPack版本,因为它支持AC701上使用的Artix-7芯片。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
You can just use the free WebPack version, since that supports the Artix-7 chip used on the AC701.
View solution in original post
举报
吕钢格
2018-12-20 11:42:29
Hi@jameson.collins,
您可以联系客户服务部门购买新的许可证。请在http://www.xilinx.com/support/service-portal.html上提交服务请求。
谢谢,Arpan -----------------------------------------------
-  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
以上来自于谷歌翻译
以下为原文
Hi @jameson.collins,
You can contact customer service for purchasing a new license.
Please file a service request on http://www.xilinx.com/support/service-portal.html
Thanks,
Arpan
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
举报
杨涛
2018-12-20 11:49:07
Hi@jameson.collins,
您必须购买新许可证才能使用最新工具。
您可以从Xilinx在线购买(http://www.xilinx.com/products/design-tools/vivado.html#buy)或
联系FAE(http://www.xilinx.com/about/contact/authorized-distributors.html)
谢谢,Nupur -----------------------------------------------
--------------------------------------------- Google在发布之前提问
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。
以上来自于谷歌翻译
以下为原文
You have to purchase a new license to use latest tools.
You can buy online from Xilinx ( http://www.xilinx.com/products/design-tools/vivado.html#buy ) or
contact a FAE ( http://www.xilinx.com/about/contact/authorized-distributors.html  )
Thanks,
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
举报
姜雨孜
2018-12-20 12:08:30
以上来自于谷歌翻译
以下为原文
举报
更多回帖
