我正在添加一些观察结果。
在安装过程中,会弹出一个错误对话框,抱怨“提取存档时遇到错误”。
它建议检查以确保我对文件夹(我这样做)有写入权限并询问是否有足够的内存空间(我有足够的空间)。
如果我选择重试,则错误消失,安装继续。
如果我从头开始重新安装,那么这些错误对于相同的档案重复很多。
但正如我之前所说,MD5值正确匹配,我已尝试拆分文件安装和单个映像安装。
以上来自于谷歌翻译
以下为原文
I'm adding a few more observations.
During installation, an error dialog box pops up several times complaining that "An error was encountered while extracting archive". It suggests checking to make sure I have write permission for the folder (I do) and questions whether there is enough memory space (I have way more than enough space). If I select retry then the error goes away and the installation continues. If I restart installation from scratch then these errors repeat pretty much for the same archives. But as I said previously the MD5 values match correctly and I have tried both the split file install and single image install.
我正在添加一些观察结果。
如果我选择重试,则错误消失,安装继续。
以上来自于谷歌翻译
以下为原文
举报
