赛灵思
直播中
李勇
8年用户 1391经验值
私信 关注
[问答]
Chipscope Pro试用许可证收到错误
我下载了试用Vivado许可证以处理旧的ISE项目,我正在尝试在设计中使用芯片范围专业版。
当我去创建位文件时,我收到以下错误:错误:NgdBuild:1316  - 尝试获取ChipScopePro许可证时遇到问题。
我认为这是因为它不喜欢我出于某种原因使用的Vivado许可证。
我的印象是vivado试用许可证允许我在30天内访问所有这些工具。
我在整个许可证管理器上寻找可以启用芯片范围专业版的东西,但我发现除了vivado试用许可证之外什么都没有?
我需要使用chipcope pro吗?
Xilinx.lic 1 KB
以上来自于谷歌翻译
以下为原文
I downloaded the trial Vivado license to work on an old ISE project, and I am trying to use chip scope pro in the design.  When I go to create the bitfile I get the following error: ERROR:NgdBuild:1316 - A problem was encountered attempting to get the
ChipScopePro license.  I assume this is because it doesn't like the Vivado license that I have for some reason.  I was under the impression that the vivado trial license would grant me access to all of these tools for the 30 days.  I looked all over the license manager for something that would enable chip scope pro, but I found nothing but the vivado trial license?  Is there a separate one that I need to use chipscope pro?
            Xilinx.lic ‏1 KB
回帖(6)
石俊梅
2018-12-14 11:58:51
你好@ bkanhofer
您附带的许可证是Vivado HLS许可证,可以单独与Vivado HLS工具一起使用。
这不适用于ISE / Chipscope。
谢谢,
迪皮卡。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
以上来自于谷歌翻译
以下为原文
Hi @bkanhofer
The license which you attached is Vivado HLS license which can be used with Vivado HLS tool alone.
This does not work with ISE/Chipscope.
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)
举报
刘美隆
2018-12-14 12:05:59
这就是我所怀疑的。
有没有办法获得ISE /芯片范围专业版的试用许可证?
以上来自于谷歌翻译
以下为原文
That's what I suspected.  Is there a way to get a trial license for ISE/chip scope pro?
举报
石俊梅
2018-12-14 12:18:52
你好@ bkanhofer
ISE 30天评估许可证可帮助您使用chipcope。
你使用的是哪种设备?
你能用Vivado吗?
我们已经停止了ISE的评估流程,并且一般不提供ISE 30天评估许可。
请联系您的Xilinx FAE以提交请求。
谢谢,
迪皮卡。
张贴。
以上来自于谷歌翻译
以下为原文
Hi @bkanhofer
ISE 30 days evaluation license helps you to use chipscope.
Which device are you using? Can you use Vivado?
We have stopped the evaluation process for ISE and ISE 30-day evaluation license is not provided generally.
Please contact your Xilinx FAE to submit the request.
Thanks,
Deepika.
Thanks,
Deepika.
举报
张琪
2018-12-14 12:26:42
我们使用的是Spartan6,所以我很确定我们会遇到ISE。
我们很快就会转向新芯片,所以我们只需要ISE和chipcope暂时进行一些维护活动。
以上来自于谷歌翻译
以下为原文
We are using a Spartan6, so I'm pretty sure we are stuck with ISE.  We are moving to a new chip soon, so we only need ISE and chipscope temporarily for some maintenance activities.
举报
更多回帖
