赛灵思
直播中
彭逸晨
8年用户 162经验值
私信 关注
[问答]
如何卸载ISE webpack并使用Vivado webpack代替
在一个愚蠢的举动中,我为ise webpack创建了一个许可证并将其加载到我的机器上。
但是,最终我真的想加载vivado的webpack许可证。
我可以删除许可证(Xilinx.lic)文件等,但是当我通过firefox或chrome访问xilinx.com/license时(我首先清除了两个浏览器缓存),下载vivado webpack的选项显示为灰色
在底部,它位于“基于激活的许可证”下。
我从管理许可部分“删除”了许可证,我怀疑该网站知道我已经下载了ISE并且现在赢了;让我访问vivado webpack许可证。
要清楚,我想使用vivado,而不是ISE。
我在ubuntu 14.04,linux 64位,我已经附加了我的xinfo文件:
提示,指针或涂料拍打赞赏:)
史蒂夫
xinfo.txt 11 KB
以上来自于谷歌翻译
以下为原文
In a boneheaded move, I created a licence for ise webpack and loaded it onto my machine.   However, ends up I really wanted to load the webpack license for vivado.  I can delete the license (Xilinx.lic) file, etc, but when I go to xilinx.com/license either via firefox or chrome (and I cleared both of the browser caches first) the option to download the vivado webpack is greyed out in the bottom section and it's under "activation based licenses".   I "deleted" the license from the manage license section, and I suspect that the website knows I've downloaded ISE and now won;t let me access vivado webpack licenses.  To be clear, I want to use vivado, not ISE.
I'm on ubuntu 14.04, linux 64 bit, and I've attached my xinfo file:
And hints, pointers, or dope slaps appreciated :)
Steve
            xinfo.txt ‏11 KB
回帖(3)
孙洪山
2018-12-13 10:33:45
好吧,我想这是通过这个线程的点点滴滴在其他地方解决的
基本上在linux上我需要在/ tools / Xilinx目录中找到以下命令
sudo ./install_fnp.sh
xlicclientmgr -cr request1.xml“ref = new”
此时我可以“firefox request1.xml”并且许可页面出现,一切都是可点击的。
所以我选择“webpack vivado”,我想我已经开始运行了。
这里详细说明,将来某人可能不必爬过更长的线程。
以上来自于谷歌翻译
以下为原文
Okay, I guess this was solved elsewhere by bits and pieces of this thread
Bascially on linux I needed to find the following commands in my /tools/Xilinx directory
xlicclientmgr -cr request1.xml "ref=new"
At which point I can "firefox request1.xml" and the license page comes up and everything is clickable.   So I select "webpack vivado" and I think I'm off and running.
Detailed here so someone in the future maybe doesn't have to crawl through a longer thread.
举报
曹兵
2018-12-13 10:49:07
嗨,
要访问基于Vivado许可证/激活的许可证,您需要通过VLM访问Xilinx许可站点。
请参阅以下链接:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug973-vivado-release-notes-install-license.pdf
谢谢,Anusheel -----------------------------------------------
-  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  - 搜索
在论坛上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关论坛并确保您的查询不会重复。
请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉-----------------------
以上来自于谷歌翻译
以下为原文
Hi,
To access the Vivado license/Activation based licenses, you need to access Xilinx Licensing Site through VLM.
Refer below link:
Thanks,
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
举报
姚庭芳
2018-12-13 11:07:48
您好steve@light.co
这是一个很好的视频:http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm
按照视频中的步骤操作并激活您的Vivado webpack许可证。
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hello steve@light.co
Here is a nice video: http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm
Follow the steps in video and activate your Vivado webpack license.
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
举报
更多回帖
