赛灵思
直播中
陈光琦
8年用户 1053经验值
私信 关注
[问答]
2014.3 VIVADO Webpack模拟器无法启动
当我尝试使用2024.3进行小型模拟时,我在TCL窗口中收到以下消息:
信息:[USF-XSim-98] ***使用args运行xsim“TESTBENCH_FOR_top_behav -key {Behavioral:sim_2:Functional:TESTBENCH_FOR_top} -tclbatch {TESTBENCH_FOR_top.tcl} -log {simulate.log}”INFO:[USF-XSim
-8]加载模拟器功能Vivado Simulator 2014.3ERROR:[Simtcl 6-50]模拟引擎无法启动:未找到模拟的有效许可证。
请运行Vivado许可证管理器以获取有关确定系统许可的功能和设备的帮助。有关详细信息,请参阅Tcl控制台或消息。
我尝试了重新安装和许可证,相同的结果....这是在webpack中禁用????
约翰
以上来自于谷歌翻译
以下为原文
When I attempt a small simulation using 2024.3 I get the following message in the TCL window:
INFO: [USF-XSim-98] *** Running xsim
with args "TESTBENCH_FOR_top_behav -key {Behavioral:sim_2:Functional:TESTBENCH_FOR_top} -tclbatch {TESTBENCH_FOR_top.tcl} -log {simulate.log}"
INFO: [USF-XSim-8] Loading simulator feature
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Please see the Tcl Console or the Messages for details.
I tried a re-install and licenses, same results....   Has this been disabled in webpack????
John
回帖(11)
石俊梅
2018-12-12 11:13:59
嗨,你能检查一下webpack的版本限制是否满足2014.3?你可以在tcl控制台中运行report_environment命令并在这里附上日志吗?谢谢,Deepika。
谢谢,迪皮卡.----------------------------------------------
---------------------------------------------- Google之前的问题
张贴。
如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。
如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星)
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi,
Can you check if the version limit of webpack satisifes 2014.3?
Can you run report_environment command in tcl console and attach the log here?
Thanks,
Deepika.
Thanks,
Deepika.
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post
举报
石俊梅
2018-12-12 11:27:12
张贴。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,
Deepika.
Thanks,
Deepika.
举报
陈衡毅
2018-12-12 11:41:25
嗨,请查看版本限制详情@ http://www.xilinx.com/support/answers/33770.htm
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi,
Please check the version limit details @ http://www.xilinx.com/support/answers/33770.htmThanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
举报
陈芮雪
2018-12-12 11:53:28
我附上了日志。
似乎不知何故获得了Vivado Webpack许可证,我设法获得了ISE许可证???
不确定是怎么回事或如何纠正它。
你可否确认?
约翰
vivado_license_dump.txt 9 KB
以上来自于谷歌翻译
以下为原文
I have attached the log.
It appears that somehow instead of getting a Vivado Webpack License, I managed to get an ISE license???   Not sure how that happened or how to correct it.   Can you confirm?
John
            vivado_license_dump.txt ‏9 KB
举报
更多回帖
