是德科技
直播中
王锦霞
8年用户 1035经验值
私信 关注
[问答]
在ADEMOD模式下无法远程编程PXA RBW和Span
在ADEMOD模式下,我无法远程编程PXA RBW和Span。
这是我使用HTBasic在SA模式下用于RBW的一切都很好:OUTPUT @ 718;
“:BAND:AUTO 0 ;:BAND:RES”& VAL $(Rbw)&“Hz”在ADEMOD模式下,这对RBW没有影响。
有什么建议么?
谢谢约翰
以上来自于谷歌翻译
     以下为原文
  I'm having difficulty remotely programming the PXA RBW and Span while in ADEMOD mode.
Here is what I Use for RBW in SA mode using HTBasic and everything is fine:
  OUTPUT @718; ":BAND:AUTO 0; :BAND :RES"&VAL$(Rbw)&" Hz"
While in ADEMOD mode, this has no effect on RBW.
Any suggestions?
Thanks
John
回帖(1)
李健
2018-12-11 16:19:11
即使它们看起来具有相同的功能,但是在不同的模式中许多命令是不同的,因为它们可能具有其他依赖性,如在这种情况下。
您可以通过按前面板的“帮助”键,然后按照您希望获取信息的键,找到几乎任何功能的正确远程命令。
在选择“帮助”之前,请务必处于您希望获取此信息的模式(在本例中为Analog Demod),因为您无法通过帮助查看模式。
最好的问候,迈克
以上来自于谷歌翻译
     以下为原文
  Even though they may appear to have the same function, many commands are different in the different modes, as they may have other dependancies, as in this case.
You should be able to find the correct remote commands for just about any function by pressing the front panel Help key and then the key that you would like the information for.
Be sure to be in the Mode you want to get this information for, in this case Analog Demod, before you select Help, as you cannot go across modes with the help.
Best regards,
Mike
举报
更多回帖
