嗨,
尝试从以下答案记录下载最新的ISE:http://www.xilinx.com/support/answers/57840.html
谢谢
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
Try downloading latest ISE from the following answer record: http://www.xilinx.com/support/answers/57840.html
Thanks
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
嗨,
谢谢
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks
举报
