嗨@nanni
您是否可以在此附上您的许可文件以确认它是基于激活的许可证还是基于证书的许可证?
基于激活的许可证不适用于ISE工具。& nbsp;
要使用ISE工具,您需要基于证书的许可证。
注意:为新查询/问题创建单独的线程始终是一种好习惯。
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi @nanni
Can you attach your license file here to confirm whether it is activation based license or certificate based license?
Activation based license do not work with ISE tools.
To work with ISE tools, you need certificate based license.
Note: It is always good practice to create a separate thread for new query/issue.
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
嗨@nanni
谢谢,
维奈
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hi @nanni
Thanks,
Vinay
举报
