嗨Ari - MXA的频率精度可以通过使用下面的“规格指南”中的N9020A MXA的频率精度规格来计算:http://cp.literature.agilent.com/litweb/pdf/N9020-90113.pdf?
cmpid = z***indmxa_specifications在第22页上,给出了频率读数精度的公式:±(标记频率×频率参考值+ 0.25%×量程+ 5%×RBWa + 2 Hz + 0.5×水平分辨率)频率参考精度等式
下面给出了第21页的MXA:±[(自上次调整后的时间×老化率)+温度稳定性+校准精度]上述术语的值也在此页面上给出。
这假设源和分析器之间的引用未锁定。
问候 -
以上来自于谷歌翻译
以下为原文
Hi Ari -
The frequency accuracy of the MXA can be calculated by using the Frequency accuracy specification for the N9020A MXA in the Specifications Guide below:
http://cp.literature.agilent.com/litweb/pdf/N9020-90113.pdf?cmpid=z***indmxa_specifications
On page 22 there is an equation given for the frequency readout accuracy:
±(marker freq × freq ref accy. + 0.25% × span + 5% × RBWa + 2 Hz + 0.5 × horizontal resolution)
The Frequency Reference Accuracy equation is given below for the MXA on page 21 :
±[(time since last adjustment × aging rate) + temperature stability + calibration accuracy]
The values for the above term are given on this page as well.
This assumes that the references between the source and the analyzer are not locked.
Regards -
这假设源和分析器之间的引用未锁定。
问候 -
以上来自于谷歌翻译
以下为原文
Hi Ari -
Regards -
举报
