是德科技
直播中
李静
8年用户 1074经验值
私信 关注
[问答]
如何从U1272A获得测量/读数?
您好,我有几个U1272A可供我使用,并希望自动获取他们的读数。
我有足够的IR-USB适配器,它们确实显示为串行设备。
我的问题是:如何从U1272A获得测量/读数?
目标是自动化测量,进入excel表(但需要更广泛的兼容性)。
我知道这些设备支持SCPI命令的子集,如果我将它们发送到正确的COM端口,我应该得到适当的响应。
事实上,它在发送* IDN时有效(有时)。
这个万用表是否有专门支持的命令列表?
我看了很多,从来没有找到一个详尽的命令列表(对于这个特定的设备或一般的SCPI)。
我安装了Agilent IO Suite以及Agilent Command Expert。
有了这些,我可以使用交互式IO发送和读取命令(只是,因为我不知道除了* IDN之外我没有得到多少命令?)。
我已经尝试通过注册设备在Excel中使用Command Expert面板,但似乎我无法连接到设备(即使它显示在Command Expert独立版中)。
任何帮助将非常感激,因为有关这方面的材料是非常稀缺的。
以上来自于谷歌翻译
     以下为原文
  Hello,
I have several U1272A's at my disposal and would like to automatically get readings from them. I have enough IR-USB adapters and they indeed show up as serial devices.
My question is: How do I get measurements/readings from the U1272A? The goal being to automate measurements, into an excel sheet (but a broader compatibility is wanted).
I understand these devices support a sub-set of the SCPI commands and if I send them one to the correct COM port, I should get an appropriate response. In fact, it does work (sometimes) when sending *IDN?.
Is there a list of the commands support specifically by this multimeter? I've looked a lot and never could find an exhaustive list of commands (be it for this particular device or SCPI in general).
I have installed the Agilent IO Suite as well as Agilent Command Expert. With these, I can use the Interactive IO to send and read commands (only, as I do not know the commands I don't get much other than *IDN?). I have tried using the Command Expert panel in Excel by registering the device, but it seems I cannot connect to the device (even if it shows up in the Command Expert standalone).
Any help would be greatly appreciated as materials regarding this is quite scarce.
回帖(1)
王霞
2018-11-28 10:50:40
只有android APP能够处理多个连接。
如果您是某种软件大师,请查看此APP以获取答案。
以上来自于谷歌翻译
     以下为原文
  Only the android APP is capable to handle multiple connections.
If you are some sort of a software Guru, check this APP for answers.
举报
更多回帖
