嗨,
我试图在FIFO /流模式下配置LIS3DH并且有一些问题,因为数据表不是很清楚。
1)我可以将INT2配置为WaterMark中断吗?我没有看到任何选项将INT2配置为寄存器位中的中断,尽管规范似乎暗示它是可能的。我们的硬件将INT2引脚连接到GPIO,因此想知道将INT2配置为水印中断是一种选择。
2)由于我无法配置INT2,因此我继续轮询FIFO_SRC_REG的WTM位以查看是否已达到水印阈值电平(假设WTM位是要查找的位置)。但是,每当我读取FIFO_SRC_REG时,它就会变为0.我在CTRL_REG5(第6位)中启用了FIFO,并将模式设置在FIFO_CTRL_REG中。我错过了什么?此外,FIFO_SRC_REG对reg位的含义没有任何解释。
以上来自于谷歌翻译
以下为原文
Hi,
I am trying to configure LIS3DH in FIFO/Stream mode and have a few ques
tions as the data sheet is not very clear.
1) Can I configure the INT2 as the WaterMark interrupt? I don't see any option to configure INT2 as the interrupt in the register bits, although the spec seems to imply it is possible. Our hardware has the INT2 pin connected to a GPIO, hence would like to know if configuring INT2 as the watermark interrupt is an option.
2) Since I couldn't configure INT2, I went with polling the WTM bit of FIFO_SRC_REG to see if the watermark threshold level has reached (assuming WTM bit is the place to look for). However, whenever I read FIFO_SRC_REG it comes out as 0. I have enabled the FIFO in CTRL_REG5 (bit 6) and set the mode in FIFO_CTRL_REG. What am I missing? Also, FIFO_SRC_REG doesn't have any explanation on what the reg bits mean.
