赛灵思
直播中
李启华
8年用户 188经验值
私信 关注
[问答]
WebPack 10.1中的功能有限
我刚下载了WebPack 10.1以匹配我大学的版本。
但是,许多功能都是灰色的,包括一些重要的功能,如“保存”和“对象属性”。
这是正常的吗?
我试图请求在线帮助,但我被阻止进入该页面。
(我以前在另一个计算机上安装了Webpack 12.3并且所有功能都在那里,除了它在学校的v.10.1不起作用。)
我需要一个新的liscense键吗?
1CL2ALWLNMJXSWSEWSLPG3CEX
请帮忙。
以上来自于谷歌翻译
以下为原文
I just downloaded WebPack 10.1 to match the version at my college.  However, many of the functions are greyed out, including some important ones like "Save" and "object properties."   Is this normal?  I tried to request online help, but I'm blocked from entering the page.
(I did previously install Webpack 12.3 on another computer and all functionality was there, except it wouldn't work with  v.10.1 at school.)
Do I need a new liscense key?
1CL2ALWLNMJXSWSEWSLPG3CEXPlease help.
回帖(3)
潘晶燕
2018-11-26 14:53:59
d,
对于大学和学校,您需要联系您的教授(讲师)。
它们具有我们分发给它们的版本,用于xupv5 pcb pcb。
Webpack不支持此板上使用的设备(仅限于小于使用的xc5vlx110t的设备)。
对于较小的设备,例如Digilent Spartan板上使用的设备,webpack就足够了。
Webcase只能由(支付)Xilinx客户提交。
对学生的支持首先来自您的学校,然后来自论坛(如此)或其他基于Internet的用户组(如comp.arch.fpga)。
十多年前,当我帮助开始第一个大学课程时,我心里对学生情有独钟(我记得那些日子),并且总会尽力帮助任何有需要的学生。
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
d,
For universities and schools, you need to contact your professor (instructor).  They have the version we distribute to them, for use with the xupv5 pcb pcb.  Webpack does not support the device used on this board (limited to devices smaller than the xc5vlx110t used).
For smaller devices, such as those used on the Digilent Spartan boards, webpack is sufficient.
Webcases may only be filed by (paying) Xilinx customers.  Support for students is first from your school, and then from forums (like this one), or other Internet based user groups (like comp.arch.fpga).
As I helped start the very first university program, more than 10 years ago now, I have a soft spot in my heart for students (I remember those days), and will always try to help any student in need.
Austin Lesea
Principal Engineer
Xilinx San Jose
举报
李思路
2018-11-26 15:13:36
保存操作通常会变灰。
除非您打开源文件并进行了更改,否则它将显示为灰色。
我不知道你看到“对象属性”的上下文。
如果打开了原理图文件并选择了一个元素,则此选项应处于活动状态。
以上来自于谷歌翻译
以下为原文
It is common to have the save operation grayed out.  It will be grayed out unless you have a source file open and have made a change.
I don't know what context you are seeing "object properties."  If you have a schematic file open, and an element selected, this option should be active.
举报
康辅佑
2018-11-26 15:19:32
我相信这个问题已经解决了。
(可能是因为我将项目保存在闪存驱动器上,然后将其保存到我的计算机上?)我需要做的就是首先在原理图屏幕上点击页面的空白部分,然后当我右键单击一个wireI canbring up时
它的属性。
经过几次不同的对象,Xilinx变得友好,所有选项现在都可用。
我真的很感谢你的回复...祝你有美好的一天!
以上来自于谷歌翻译
以下为原文
I believe the issue has been resolved.  (Possibly due to me having the project saved on a flash drive and then saving it onto my computer?)  All I needed to do was to first click on a blank part of the page on the schematic screen, and then when I right clicked on a wire I could bring up its properties.  After a couple of times doing this with different objects, Xilinx became friendly and all of the options are now available.  I really appreciate your replies... have a great day!
举报
更多回帖
