英特尔
直播中
李乔
8年用户 168经验值
私信 关注
[问答]
如何擦除optane 905P SSD?
普通的SSD可以使用可启动的Parted Magic USB记忆棒安全擦除。
此程序是否适用于905Ps,还是有其他程序?
以上来自于谷歌翻译
以下为原文
Ordinary SSDs can be securely erased using a bootable Parted Magic USB stick. Does this procedure apply to 905Ps, or is there another procedure?
回帖(7)
汤宇
2018-11-23 12:00:46
您好tseax,感谢您在英特尔®SSD社区中发布您的问题。在以下链接中,您将找到执行安全擦除的过程:https://www.intel.com/content/www/us/en/support/
文章/ 000022179 / memory-and-storage.html您可以使用以下命令:
列表磁盘:显示连接磁盘和USB闪存驱动器列表Sel磁盘(选择磁盘):选择要在全部清除的范围:从所选设备中删除分区和卷信息请记住,在主SSD中无法执行安全擦除
正在运行。希望此信息对您有所帮助,如果您有任何其他问题请告诉我。最好的问候,Juan N.
以上来自于谷歌翻译
以下为原文
Hello tseax,
Thanks for posting your question in the Intel® SSD community.
In the following link you will find the procedure to perform a secure erase:
https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html
You can use the following commands:
  • List disk: Displays the list of attached disks and USB flash drives
  • Sel disk (select disk): Selects the scope to work in
  • Clean all: Removes partition and volume information from the selected device
Remember you cannot perform a secure erase in the primary SSD while it is running.
Hope this information helps you, if you have any additional question let me know.
Best Regards,
Juan N.
举报
李玉鑫
2018-11-23 12:20:30
列表磁盘:显示连接磁盘和USB闪存驱动器列表Sel磁盘(选择磁盘):选择要在全部清除的范围:从所选设 ...
谢谢你回复Juan N.
我应该指定,Parted Magic是一个可启动的工具,用于擦除系统SSD以准备重新安装操作系统。
它是一个类似的离线可启动工具(也许Parted Magic就足够了,我还不知道)我正在寻找。
905P将是系统盘。
Parted Magic通常只需几秒钟就可以擦除传统的闪存驱动器。
我想知道相同的程序对905P生产线是安全的还是适用的。
以上来自于谷歌翻译
以下为原文
Thank you for the reply Juan N.
I should have specified, Parted Magic is a bootable tool used to erase a system SSD in preparation for OS reinstallation. It is a similar offline bootable tool (perhaps Parted Magic would suffice, I don't know as yet) that I'm looking for. The 905P will be the system disk. Parted Magic normally takes only seconds to wipe a conventional flash memory drive. I'm wondering whether the same procedure is safe for, or applicable to, the 905P line.
举报
汤宇
2018-11-23 12:39:12
引用: cd340823 发表于 2018-11-23 13:12
谢谢你回复Juan N.
你好tseax,谢谢你的澄清。从软件的角度来看,905P是一款普通的SSD。
在检查PartedMagic网站中的可用信息后,它不显示对PCIe或U.2存储的任何支持。
建议你直接询问PartedMagic他们对这种SSD的支持。最好的问候,Juan N.
以上来自于谷歌翻译
以下为原文
Hello tseax,
Thanks for the clarification.
The 905P is a regular SSD from the software point of view.  After checking the available information in the PartedMagic website it does not show any support for a PCIe or U.2 storage. It would be recommended for you to ask PartedMagic directly about their support for this kind of SSDs.
Best Regards,
Juan N.
举报
李乔
2018-11-23 12:55:48
您好tseax,我想知道您是否对此问题有任何其他疑问?最诚挚的问候,Juan N.
以上来自于谷歌翻译
以下为原文
Hello tseax,
I would like to know if you have any additional question regarding this issue?
Best Regards,
Juan N.
举报
更多回帖
