大家好
如何正确设置FX3频率到400 MHz?
因为我现在测试GPIO纯输出0和1,我看到我的示波器上的45.9kHz。
这是我的FX3固件:
BulkPopthTraceRead():
空BulkPopthTraceEnter(U
tiT32×T输入)
CYU3PGPIOCROCKILT GPIOCROCK;
GPIOCROC.FASTLKDIV=2;
速度慢=0;
SimeDIV= CYU-U3PGGPIOSIMPLE和DIVYBYY2;
CKYSRC= CYU-U3PySysLCK;
半英寸=0;
CYU3PGPIOIIT(和GPIOCROCK,NULL);
CYU3PGPIOSLIVIGICONFIGHTGPIOCOFIG;
GPIOCONTION.OUTVAIL = CyTress;
GPIOCONTION IMPUTEN = CyFLUE;
GPIO构型。
GPIO配置。
GPIOCONTIONIN模式= CYU-U3PGPIOONIONITER;
CYU3PGPIOSETSimuleFig(45,GPIOCONFIG);
为(;;){
CYU3PGPIOSET值(45,CyFalse);
CYU3PGPIOSET值(45,CyTrue);
CyFxApplicationDefine();
无效CyFxApplicationDefine(空)
空白* PTR=NULL;
UIT32 32 T ReTrdReCyt = CyuU3pl成功;
PtR=CYU3pMeMeloC(CyfxxBulkpl thRead堆栈);
ReTrdCudio= Cyu3pthRead Cube(和BulkPAPPthLoad)
“21:BulkyLoopyAuto.”
BulkPAPTHeRead条目,
0,
PTR
CyfxxBulkpLthRead堆栈,
CyfxfxBulkpLthRead优先级
Cyu3PyNoiTimeIn切片,
CYU3PYAutoSoad
如果(ReTrdDebug)!= 0)
(1);
主体:()
int(空){/1
CYU3PRESTROSTATUS SWT状态= CYU-U3PY成功;
Cyu3PysCyClinux配置时钟;
CysTysCLK400 = Cytru;
CopyToCcLo.CPULKDIV=2;
组态CcLo.dMaCLKDIV=2;
组态CcLo.MmioCLKDIV=2;
CopyCcLo.USTEnand ByCLK=CyFLY;
CythUncL.CKSRC= CyuU3PySysLCK;
状态= CYU3PDEVICEIIT(&配置文件时钟);
如果(状态)!= CYU-U3PY成功
Goto Houel-FATALL错误;
状态= CYU3PDEVICECACHECL(Cyress,Cyrtrut,CyFalse);
如果(状态)!= CYU-U3PY成功
CYU3PIOMATAXXCONTILT IOFCFG;
CYU3PMESET((UIT88T**)和;IOIF CFG,0,SIZEOF(IO-CFG);
IOFCFG.ISDQ32位=CyFLY;
IOFCFG.S0MODE=CYU-U3PL运动活性;
IOFCFG S1MODE=CYU-U3PL运动活性;
IOFCFG.UUEART=CyFLY;
IOFCFG.UIE2C=CyFrE;
IOFCFGUSE2S=CyFrE;
IOFCFG.UESSPI= CyFLY;
IOFCFG.LPPMODE=CyuU3pIIO-MatRIX-LPPH默认;
IopyCFG.GPIOSLIMEN〔0〕=0x00亿;// 0~31
IOICFG.GPIOSLIMEN〔1〕=0X000 000;
IOFCFG。GPIO-络合〔0〕=0;
IOFCFG。GPIO-络合〔1〕=0;
状态= CYU3PDEVICECOMPIORIICOMATRIX(和;IOYCFG);
如果(状态)!= CYU-U3PY成功
CYU3pKelnEnter();
返回0;
HANDLY-FATALL错误:
(1);
我遗漏了什么东西吗?
以上来自于百度翻译
以下为原文
Hello, everyone
How do I set the FX3 frequency to 400Mhz correctly?
Because I now test GPIO for pure output of 0 and 1, I see 459.39Khz on my oscilloscope.
Here is my FX3 firmware:
BulkLpAppThread_Entry():
void BulkLpAppThread_Entry ( uint32_t input) { CyU3PGpioClock_t gpioClock; gpioClock.fastClkDiv = 2; gpioClock.slowClkDiv = 0; gpioClock.simpleDiv = CY_U3P_GPIO_SIMPLE_DIV_BY_2; gpioClock.clkSrc = CY_U3P_SYS_CLK; gpioClock.halfDiv = 0; CyU3PGpioInit(&gpioClock, NULL); CyU3PGpioSimpleConfig_t gpioConfig; gpioConfig.outValue = CyTrue; gpioConfig.inputEn = CyFalse; gpioConfig.driveLowEn = CyTrue; gpioConfig.driveHighEn = CyTrue; gpioConfig.intrMode = CY_U3P_GPIO_NO_INTR; CyU3PGpioSetSimpleConfig(45, &gpioConfig); for (;;){ CyU3PGpioSetValue (45,CyFalse); CyU3PGpioSetValue (45,CyTrue); }}
CyFxApplicationDefine ();
void CyFxApplicationDefine (void) { void *ptr = NULL; uint32_t retThrdCreate = CY_U3P_SUCCESS; ptr = CyU3PMemAlloc (CY_FX_BULKLP_THREAD_STACK); retThrdCreate = CyU3PThreadCreate (&BulkLpAppThread, "21:Bulk_loop_AUTO", BulkLpAppThread_Entry, 0, ptr, CY_FX_BULKLP_THREAD_STACK, CY_FX_BULKLP_THREAD_PRIORITY, CY_FX_BULKLP_THREAD_PRIORITY, CYU3P_NO_TIME_SLICE, CYU3P_AUTO_START ); if (retThrdCreate != 0) { while(1); }}
main():
int main (void){ //1 CyU3PReturnStatus_t status = CY_U3P_SUCCESS; CyU3PSysClockConfig_t CONFIG_CLOCK; CONFIG_CLOCK.setSysClk400 = CyTrue; CONFIG_CLOCK.cpuClkDiv = 2; CONFIG_CLOCK.dmaClkDiv = 2; CONFIG_CLOCK.mmioClkDiv = 2; CONFIG_CLOCK.useStandbyClk = CyFalse; CONFIG_CLOCK.clkSrc = CY_U3P_SYS_CLK; status = CyU3PDeviceInit (&CONFIG_CLOCK); if (status != CY_U3P_SUCCESS) { goto handle_fatal_error; } status = CyU3PDeviceCacheControl (CyTrue, CyTrue, CyFalse); if (status != CY_U3P_SUCCESS) { goto handle_fatal_error; } CyU3PIoMatrixConfig_t io_cfg; CyU3PMemSet ((uint8_t *)&io_cfg, 0, sizeof(io_cfg)); io_cfg.isDQ32Bit = CyFalse; io_cfg.s0Mode = CY_U3P_SPORT_INACTIVE; io_cfg.s1Mode = CY_U3P_SPORT_INACTIVE; io_cfg.useUart = CyFalse; io_cfg.useI2C = CyFalse; io_cfg.useI2S = CyFalse; io_cfg.useSpi = CyFalse; io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT; io_cfg.gpioSimpleEn[0] = 0x00000000; //0~31 io_cfg.gpioSimpleEn[1] = 0x00002000; //45 on io_cfg.gpioComplexEn[0] = 0; io_cfg.gpioComplexEn[1] = 0; status = CyU3PDeviceConfigureIOMatrix (&io_cfg); if (status != CY_U3P_SUCCESS) { goto handle_fatal_error; } CyU3PKernelEntry (); return 0;handle_fatal_error: while (1);}
Am I missing something set?
