赛灵思
直播中
康大争
8年用户 2258经验值
私信 关注
[问答]
Xilinx ISE 11.1 Webpack不会开设新项目
我安装了Xilink ISE 11.1,卸载并重新安装。
每次程序打开,但当我尝试打开一个新项目时,我收到以下消息:
Fatal_error:GuiUtilities:GuiClip_ApplicationBase.c:316:1.20  - 此应用程序执行了一个illigal操作,必须关闭。
流程将终止。
有关此问题的技术支持,请打开一个WebCase,该项目附在http:www.xilinx.com/support上。
随后是关闭程序的消息。
这是一台Windows XP平板电脑。
在安装过程中没有错误消息,应用程序似乎正确安装。
我也能够毫无问题地安装xilinx.lic文件。
任何帮助将不胜感激。
谢谢。
以上来自于谷歌翻译
以下为原文
I have installed Xilink ISE 11.1, uninstalled and reinstalled.  Each time the program will open, but when I try to open a new project I receive the following message:
Fatal_error:GuiUtilities:GuiClip_ApplicationBase.c:316:1.20 - This application has performed an illigal operation and must be shut down. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http:www.xilinx.com/support.
Followed by a message closing the program.
This is a Windows XP Tablet PC.  During the install there were no error messages and the application appeared to install properly.  I was also able to install the xilinx.lic file with no problems.
Any help would be greatly appreciated.
Thank you.
回帖(4)
沈会笛
2018-11-15 11:51:05
我在Windows 7 32bit上看到了这一点
以上来自于谷歌翻译
以下为原文
I see this on Windows 7 32bit
举报
卓侨汉
2018-11-15 12:09:36
如果你使用win vista& win 7 pls open program as admin如果你不这样做,你会看到错误。
以上来自于谷歌翻译
以下为原文
if you use win vista &win 7 pls open program as admin if you don't you will seen error.
举报
王红梅
2018-11-15 12:15:13
我使用ISE 11.1开发了同样的问题。
除了创建一个新项目(包括cloding和打开已经创建的项目),我可以做任何事情。
我在安装ISE webpack之后没有立即得到这个错误,而是我已经创建了大约4个项目,而现在又遇到了这个问题!
oolesen80,你有没有找到修复?
以上来自于谷歌翻译
以下为原文
I've developed this very same problem using ISE 11.1.  I can do everything but create a new project (including cloding and opening already created projects).  I didn't get this error right away after installing ISE webpack, rather I've created about 4 projects and hav now just run into this issue!  oolesen80, did you ever find a fix?
举报
李思路
2018-11-15 12:27:23
请参阅:http://www.xilinx.com/support/answers/32800.htm
以上来自于谷歌翻译
以下为原文
See: http://www.xilinx.com/support/answers/32800.htm
举报
更多回帖
