Cypress技术论坛
直播中
李月如
7年用户 144经验值
私信 关注
[问答]
CYBLE-022001-00 EZ PRoC模块是否支持Mesh Networking
有什么限制会阻止这个模块实现BT Mesh网络的任何角色吗?节点,中继,代理,Friend Low Power?它能与蓝牙网络中的相同和不同的BLE模块互操作吗?
以上来自于百度翻译
     以下为原文
  Are there any limitations that would prevent this module from fulfilling any role of a bt mesh network? Node, Relay, Proxy, Friend Low Power?  Can it interoperate with the same and different BLE modules in a bluetooth network?
回帖(3)
黎歆俭
2018-11-14 09:48:45
根据这篇文章:HTTPS://www. ErrsSun.COM/AsEss/Loal/Pusiths/Waldi-Posis/WP-蓝牙-MESH-C3.PDF
没有限制,因为它只需要一个固件升级作为一个BLE网格节点工作。BLE V4.0和V5.0的硬件要求与BLE网格相同。
如果您可以比BLE规范更清楚地描述或列出每个设备/角色的要求,这将是有帮助的,但是,否则读取SPEC似乎表明,即使不是所有的BLE网格需求,都是在芯片上运行的软件实现,而不是硬件本身。
以上来自于百度翻译
     以下为原文
  According to this article: https://www.ericsson.com/assets/local/publications/white-papers/wp-bluetooth-mesh-c3.pdf
There are no limitations, as it only requires a firmware upgrade to work as a BLE mesh node. The hardware requirements for BLE v4.x and v5.0 are the same as for BLE Mesh.
If you can describe or list the requirements of each device/role more clearly than the BLE spec, it would help, but otherwise reading the spec seems to indicate that most if not all of the BLE mesh requirements are software implementations running on the chip, and not the hardware itself.
举报
李月如
2018-11-14 10:04:15
如果您可以比BLE规范更清楚地描述或列出每个设备/角色的要求,这将是有帮助的,但是,否则读取SPEC似乎表明,即使不是 ...
谢谢你的回答。我有PDF打开,还有很多其他的浏览器在我的类型。现在我只需要阅读它。我仍然处于早期开发阶段,所以我还在学习。再次感谢。
以上来自于百度翻译
     以下为原文
  thank you for your answer. I have that pdf open, along with many others on my browser as I type. Now I just need to read it. I'm still in the early development phase so I'm still learning. Thanks again.
举报
鲁玉萍
2018-11-14 10:17:30
以上来自于百度翻译
你好,
我们没有网格支持PSOC4BLE。支持BLE网格的设备-CYW20706(即将发布的WICE)和CYW20719。也有不广泛的市场设备CYW20735,但你必须联系销售办事处与您的项目细节和数量的细节。
谢谢,
希马
以上来自于百度翻译
     以下为原文
  Hello,
We do not have Mesh support for PSoC4-BLE. Devices that support BLE mesh - CYW20706 (upcoming releases of WICED) and CYW20719. There are also non broad-market device CYW20735 but you will have to contact the sales office with your project details and quantity details.
Thanks,
Hima
举报
更多回帖
