嗨@ poornima_95。
目标部件是7系列设备吗?
该消息看起来如此,但我想确认一下。
另外,您能指出消息中两个实例的原语类型吗?
形状是内部生成的相对放置的宏,旨在帮助place_design。
IO实例需要具有正确的相对坐标。
此消息表示形状内存在重叠。
我会尝试检查两个内核是否存在冲突的IO约束。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi @poornima_95. Is the target part a 7-Series device? The message looks to indicate so, but I wanted to confirm. Also, can you indicate what type of primitives the two instances in the message are?
A shape is an internally generated relatively placed macro that is intended to assist place_design. IO instances would need to have the correct relative coordinates. This message would indicate that there is overlap within the shape. I would try checking if the two cores have conflicting IO constraints.
View solution in original post
嗨@ poornima_95。
目标部件是7系列设备吗?
该消息看起来如此,但我想确认一下。
IO实例需要具有正确的相对坐标。
此消息表示形状内存在重叠。
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
举报
