嗨,喝水,E4407B使用SCPI程序,只需要一个简单的VEE Direct IO对象即可通过GPIB或RS232串行接口向/从设备发送/接收数据。
请参阅附加的示例,该示例抓取ESA屏幕图像。
尝试浏览此页面上的一些示例:[http://www.keysight.com/main/editorial.jspx?cc=GB&lc=eng&ckey=407788&nid=-33932.710346.02&id=407788&
cmpid = 94444]或者在本文档中:[http://literature.cdn.keysight.com/litweb/pdf/E4401-90482.pdf]您可能希望浏览ESA系列的编程指南:[http:/
/literature.cdn.keysight.com/litweb/pdf/E4401-90507.pdf]和[http://literature.cdn.keysight.com/litweb/pdf/E4440-90618.pdf]。
您可能还会发现Command Expert实用程序中的内置帮助很有用。
有关此工具的更多详细信息,请参见此处:[http://www.keysight.com/en/pd-2036130/command-expert?nid=-35491.992473.00&cc=GB&lc=eng]我希望这会有所帮助,
干杯,西蒙C.
以上来自于谷歌翻译
以下为原文
Hi souparno,
The E4407B uses the SCPI program langage, and a simple VEE Direct IO object is often all that is needed to send/receive data to/from the unit, over the GPIB or RS232 Serial interface. See attached example that grabs the ESA screen image.
Try browsing some of the examples on this page:
[http://www.keysight.com/main/editorial.jspx?cc=GB&lc=eng&ckey=407788&nid=-33932.710346.02&id=407788&cmpid=94444]
Or in this document:
You may like to browse the programming guides for the ESA-Series:
[http://literature.cdn.keysight.com/litweb/pdf/E4401-90507.pdf]
and
[http://literature.cdn.keysight.com/litweb/pdf/E4440-90618.pdf].
You may also find the inbuilt help in the Command Expert utility to be useful.
See here for more detail on this tool:
I hope this helps,
Cheers, Simon C.
附件
干杯,西蒙C.
以上来自于谷歌翻译
以下为原文
Hi souparno,
and
I hope this helps,
Cheers, Simon C.
附件
举报
