Microchip
直播中
华农武
7年用户 225经验值
私信 关注
[问答]
ICD 4调试在没有警告的情况下重新启动
你好!我买了一个ICD 4几个月前,因为我炒我的ICD3工作得很好。自从我开始使用ICD4以来,我调试了很多问题。1)它经常在没有警告的情况下重新启动。2)如果在启动调试设置时设置了超过3个断点,那么MPLABX挂在“设置项目断点”3上。调试工具已经出现。该工具将尝试暂时恢复。“调试时,我得到很多。我记得在使用ICD3时遇到了一些问题,但在任何地方我都能看到ICD4所看到的问题。为什么会这样?有没有办法升级ICD4固件,这会有帮助吗?我不能继续这样工作……(我使用MPLABX V4.05,XC8 V 1.34编程PIC18F70J11和PIC18F26K20,我已经尝试了由USB供电的ICD4,由电源供电)/比约恩
以上来自于百度翻译
      以下为原文
    Hello!
I bought an ICD 4 a couple of moths ago since I fried my ICD3 that was working well. Since I started using the ICD4 I have a lot of problems debugging.
1)every now and then it restarts without warning.
2) If I have more than 3 breakpoints set when initiating a debug settings then MplabX hangs on "setting project breakpoints"
3) I get the following message "A communication error with the debug tool has occurred. The tool will attempt to recover momentarily." while debugging, and I get it a lot.
I remember having a few problems when I was using the ICD3 but anywhere close to the amount of problems that I see with the ICD4. Why is this? Are there any way to upgrade the ICD4 firmwars, and would that help? I can't go on working like this..
(I'm using MplabX v4.05, XC8 v 1.34 programming PIC18F87J11 and PIC18F26K20 and I have tried the ICD4 powered by USB and powered by a power supply)
//Bjorn
回帖(5)
陈晨
2018-11-2 15:03:45
尝试MPLABX V4.10,您可能能够得到您的ICD3修复。
以上来自于百度翻译
      以下为原文
    Try MPLabX V4.10
You might be able to get your icd3 repaired.
举报
路云芳
2018-11-2 15:17:00
我从来没有想过这样的选择,但我认为我需要一个全新的PCB(基本上是整个产品)。我把它插进我的USB集线器,我用19V来代替5V(坏错误)。印制电路板油炸,并有一个大的黑色烧伤痕迹。既然我的ICD3和垃圾一起出去了,现在就要迟到了。
以上来自于百度翻译
      以下为原文
    I never thought about that option, but I think that I would have needed a brand new PCB (which basically is the whole product). I plugged it into my USB hub which I supplied with 19V instead of 5V (bad mistake). The PCB got fried and had a big black burn mark on it.. Now it's to late anyway since my ICD3 went out with the trash :(
举报
陈晨
2018-11-2 15:36:25
尝试它的最新版本。这是一个新产品,并更新更多。还要注意的是,有一个ICD4特定论坛和一个电子邮件地址。
以上来自于百度翻译
      以下为原文
    Try it with the latest version. It is a new product and is updated more. Also note there is an icd4 specific forum, and an email address.
举报
路云芳
2018-11-2 15:51:03
好吧,也许我应该试着移动这个帖子……你知道如何更新固件吗?我在MpLabX的ICD4设置中购买了“使用最新固件”
以上来自于百度翻译
      以下为原文
    ok, Maybe I should try and move this post then..
Do you know how to update the firmware? I have ticket the box "use latest firmware" in the ICD4 settings in MpLabX
举报
更多回帖
