英特尔
直播中
陈勇
7年用户 1245经验值
私信 关注
[问答]
S2600CP无效的dimm配置
嗨,我希望有人知道这里发生了什么
我有S2600CP主板,它可以很好地工作2x 2609 cpu但不适用于2x 2660v2 cpu
我已经将主板BIOS更新到最新版本的BIOS - 02.06.0006我仍然总是收到此错误
但如果我只使用其中一个,它也会工作,我也检查了led邮政编码意味着什么,并且简而言之
它点亮了数字7 6 5和3 2 1
我开始撕裂我的头发试图找出问题所在
我使用的ram是在4支装上以1333mhz非ecc进行的8演出,并且RAM可以正常使用2609 cpu
如果我遗失任何东西,我非常想听听它,或者你是否有一个神奇的解决方案
138.6 K.
以上来自于谷歌翻译
以下为原文
hi there i hope someone knows whats going on here
i have the S2600CP motherboard  where it works perfectly fine with 2x 2609 cpu´s but will not work with 2x 2660v2 cpu´s
i have updated the motherboard bios to the latest version BIOS  - 02.06.0006 i still always get this error
but it will work if i just use one of them i have also check what the led post code means and that came up short
it lights up led numbers 7 6 5 and 3 2 1
i am starting to tear my hair trying to figure out what the problem
the ram im using is 8 gigs on 4 sticks at 1333mhz non ecc and the ram works just fine with the 2609 cpu´s
if i am missing anything i would very much like to hear about it or if you have a magic solution for this
回帖(8)
汤宇
2018-10-30 11:40:01
您好Atil,感谢您加入社区。根据ark.intel.com,您正在使用的处理器型号受此板支持,因此不应该是问题。关于RAM配置您想要遵循上面描述的内存填充规则
本主板的技术产品规格文件(第4.2.2.1节)。
第4.1节也支持处理器。请仔细看看这个,如果问题仍然存在,请告诉我们。希望这有助于.Jose A.
以上来自于谷歌翻译
以下为原文
Hello Atil,
Thanks for joining the community.
According to ark.intel.com both processor models that you are using are supported by this board, so that should not be the issue.
About the RAM configuration you want to follow the memory population rules depicted on the Technical Product Specifications document (section 4.2.2.1) for this board. Also processor supported is in section 4.1.
Please take a careful look at this and let us know if the issue persist.
Hope this helps
Jose A.
举报
李玉鑫
2018-10-30 11:49:00
我已经通过手册,似乎没什么帮助
我试过把所有ram模块通道A和B放在什么都没做
在A频道放2支,在E频道放2个,我甚至没有试过在A1插槽中只用1根棍子但仍然没有
我甚至尝试填充A1插槽,C1插槽,E1插槽和G1插槽仍然没有变化
当我用一根ram做的时候我尝试了A1插槽我尝试了3种不同的ram仍然没有通过无效的dimm配置
以上来自于谷歌翻译
以下为原文
i have been trough the manual and it seems to be of little help
i have tried putting all ram modules channels A and B that did nothing
put 2 sticks in the A channel and 2 in the E channel still nothing i have even tried with just 1 stick in the A1 slot but still nothing
i even tried populating the A1 slot, C1 slot, E1 slot and G1 slot still no change
i did try the A1 slot when i did it with a single stick of ram i tried 3 different sticks of ram still it would not get past invalid dimm configuration
举报
汤宇
2018-10-30 11:59:49
引用: cd340823 发表于 2018-10-30 12:27
我已经通过手册,似乎没什么帮助
您好Atli,当您收到错误消息时,是否有任何内存插槽LED指示灯亮起?您可以尝试以下最小配置:2 x 2660v2处理器,通道A1中的1个DIMM和E1Besides通道中的1个DIMM,您可以将部件号发送给我们
内存DIMM,所以我们可以确认它们是否被验证.Jose A.
以上来自于谷歌翻译
以下为原文
Hello Atli,
Is there any memory slot LED illuminating when you get the error message?
Could you try the following minimal configuration:
2 x 2660v2 processors, 1 DIMM in channel A1 and 1 DIMM in channel E1
Besides that could you please send us the part numbers of the memory DIMMs so we can confirm if they are validated
Jose A.
举报
陈勇
2018-10-30 12:19:21
我确实尝试了最小的配置,但仍然没有运气甚至尝试回到bios版本(02.03.003)我希望最新的BIOS有点错误,似乎不是这样的
至于ram stick我有以下几点:
mushkin blackline 996677 x4(2gb stick)
海盗船cmv4gx3m1a1600c11 x1(4gb棒)
hynix hmt325u6cfr8c - h9 x1(2gb棒)
我可以在双模式下运行2609或在单模式下运行2660v2时混合所有这些,但我主要使用糊状棒作为我的主要测试棒
当我收到此错误时,ram插槽旁边也没有指示灯
以上来自于谷歌翻译
以下为原文
i did try the minimal configuration and still no luck even tried going back a bios version (02.03.003) i was hoping the latest bios was somehow faulty that does not seem to be the case
as for the ram sticks i have they are the following:
mushkin blackline 996677    x4 (2gb stick)
corsair cmv4gx3m1a1600c11    x1 (4gb stick)
hynix hmt325u6cfr8c - h9     x1 (2gb stick)
i can mix all of them when running the 2609 in dual mode or the 2660v2 in single mode but i have been mainly using the mushkin sticks as my primary test sticks
also there are no lights next to the ram slots when i get this error
举报
更多回帖
