嗨@ quincyq2003,
你能分享用于初始化FF的代码吗?
因为FF的值会随着时钟边沿而改变,如果你使用的是高频时钟,那么你可能无法注意到它。
谢谢,Arpan -----------------------------------------------
- - - - - - - - - - - - - - - - - - - - - - - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
以上来自于谷歌翻译
以下为原文
Hi @quincyq2003,
Can you share the code used to initialize FF?
Because the value of FF will change with the clock edge and if you are using high frequency clock then you may not be able to notice the same.
Thanks,
Arpan
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
嗨@ quincyq2003,
你能分享用于初始化FF的代码吗?
以上来自于谷歌翻译
以下为原文
Hi @quincyq2003,
Thanks,
Arpan
举报
