是德科技
直播中
王娟
8年用户 464经验值
私信 关注
[问答]
Tektronix 370A的数据存储如何修复代码
最近我一直在使用VEE 9.2来捕获工具屏幕上的曲线数据。
我现在可以保存一些东西,但数据不正确。
工具手册中的描述如下:“曲线数据集通常比任何其他类型都长。通常一组曲线数据长约4122字节,大多数字节是二进制编码的数字。因此,大多数
数据串不能直接读取,但必须由控制器解释。“
我附上我写的代码,我导出的数据和手册pic。
任何人都可以建议我如何修复代码?
谢谢CURVE.C1710.7 KBTektronix 370A DIV test.vee8.7 KB
以上来自于谷歌翻译
     以下为原文
  Recently I have been working on using VEE 9.2 to capture the curve data on the tool screen.
I can save something now but the data is not correct.
The description in the tool manual is as follows,
"Curve data sets are usually much longer than any other kind. Typically a set of curve data will be about 4122 bytes long, with most of the bytes being binary-coded numbers. Thus, most of the string of data is not directly readable, but must be interpreted by the controller."
I attach the code I write, the data I export, and the manual pic.
Can anybody suggest me how to fix the code?
Thanks
附件
回帖(1)
何洁萍
2018-10-25 11:20:09
嗨Yashi,嗯,我可以看到你把单元中的数据写成CURVE.C17文件作为二进制字符串数据。
因此,从逻辑上讲,将其作为二进制字符串数据读回应该可以恢复原始数据。
附加程序执行此操作,并绘制结果数组。
我不知道这是你想要的图像,但它应该让你走上正确的轨道。
干杯,西蒙C.
以上来自于谷歌翻译
     以下为原文
  Hi Yashi,
Well, I can see you wrote the data from the unit to the CURVE.C17 file as binary string data.
So, logically, reading it back as binary string data should recover the original data.
The attched program does this, and plots the resulting array.
I have no idea if this is the image you were expecting, but it should get you on the right track.
Cheers, Simon C.
附件
举报
更多回帖
