我将源时钟除以2,然后尝试将其输入DCM(首先通过缓冲区)。
但我得到的错误是我无法解释的:
错误:NgdBuild:455 - 逻辑网络'clk25'有多个驱动程序:块clk25上的引脚Q,类型为FDC,块上的引脚PAD为clk25.PAD,类型为PADERROR:NgdBuild:462 - 输入焊盘网'clk25'驱动多个
缓冲器:块cgate / u_ibuf上的引脚I,类型为IBUF,引脚I上的块clk25_INV_1_o1_INV_0,类型为INVERROR:NgdBuild:924 - 输入焊盘网'clk25'驱动非缓冲原语:块c上的引脚Q,类型为FDC
我还在.bld文件中找到了一些INFO消息,我不明白。
信息:NgdBuild:889 - 在此设计中,Pad net'clk25'未连接到外部端口。
添加了一个新端口'clk25'并连接到该信号。
我只是将时钟分成如下,然后将clk25送入DCM:
cg1:进程(clk_src,rst)如果rst ='1'则开始,然后clk25 elsif clk_src'event和clk_src ='1'然后clk25结束if;
结束过程;
以上来自于谷歌翻译
以下为原文
I am dividing my source clock by 2, then trying to feed this into a DCM (through a buffer first). But I get errors which I cannot explain:
ERROR:NgdBuild:455 - logical net 'clk25' has mul
tiple driver(s):
pin Q on block clk25 with type FDC,
pin PAD on block clk25.PAD with type PAD
ERROR:NgdBuild:462 - input pad net 'clk25' drives multiple buffers:
pin I on block cgate/u_ibuf with type IBUF,
pin I on block clk25_INV_1_o1_INV_0 with type INV
ERROR:NgdBuild:924 - input pad net 'clk25' is driving non-buffer primitives:
I also found some INFO message in the .bld file, which I don't understand.
INFO:NgdBuild:889 - Pad net 'clk25' is not connected to an external port in this
design. A new port 'clk25' has been added and is connected to this signal.
I am simply dividing the clock as below, then feeding clk25 into the DCM:
cg1 : process(clk_src, rst)
begin
if rst = '1' then
clk25 <= '0';
elsif clk_src'event and clk_src='1' then
clk25 <= not clk25;
end if;
end process;
