Hellojamiedow,感谢您在英特尔®社区发帖。我可以看到您在通过HDMI将NUC连接到电视时遇到问题。请注意,为了更好地帮助您处理您的请求,我需要检查一些有关您计算机的信息
请按照以下步骤操作:1。
在键盘上,按WinLogo键+ R.2。
在运行框中,输入dxdiag并按Enter.3。
单击“保存所有信息”(将其保存在桌面上).4。
将报告附加到此线程。此外,尝试将不同的HDMI设备连接到电视以确保电缆或系统没有故障非常重要。
除此之外,您还可以尝试使用不同的电缆或其他HDMI显示器进行测试。请注意,David VIntel客户支持技术人员是否与英特尔公司签订合同
以上来自于谷歌翻译
以下为原文
Hello
jamiedow,
Thank you for posting on the Intel ® communities.
I can see that you are having problems connecting the NUC to the TV via HDMI.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Also, It is important to try to connect a different HDMI device to the TV to make sure that the cable or the system are not at fault. Aside from this, you can also try using a different cable or else a different HDMI display for testing purposes.
Regards,
David V
Intel Customer Support Technician
Under Contract to Intel Corporation
请按照以下步骤操作:1。
以上来自于谷歌翻译
以下为原文
Hello
jamiedow,
Regards,
David V
举报
