好的,绝对可行,但不是图表最直接的应用。
我附上了一个看起来像你的电子表格的例子。
注意:映射的所有输入都是数据 - >常量 - > Real64,但一般情况下,如果(a)对象标题被短的&更改,则更容易读取程序。
有意义的
(b)然后通过点击图表LHS上的Trace 1来最小化它们改变痕迹颜色(名称等),或者你可以通过进入属性(左下窗口)找到它们,找到Traces并点击
...打开一个对话框,可以通过单击Y名称将Y比例从自动更改为固定,同样可以如上所述设置具有X名称或两者的X比例,但是对于Scales属性,可以向图形添加额外的跟踪
通过图形对象的菜单添加终端 - >数据输入...同样将映射值引脚添加到数据 - >访问数组 - >设置映射对象,单击对象菜单添加终端 - >数据输入然后选择映射从1
,再次执行相同操作以获取Map To 1输入引脚。
如果有什么不清楚,那就继续问!
迈克沃茨
以上来自于谷歌翻译
以下为原文
Ok, definitely doable but not the most straightforward application of the charts. I have attached an example which looks like your spreadsheet.
Notes:
all of the inputs to the mappings are Data -> Constant -> Real64 but in
general it is easier to read the program if (a) object titles are
changed with something short & meaningful & (b) they are then minimised
change the trace colours ( names and so forth ) by clicking on Trace 1
on the LHS of the graph or you can get to them by going into the
properties ( left lower window ), find Traces and click on the ... to
open a dialog box
the Y scale can be changed from auto to fixed by clicking on Y name,
likewise X scale with X name or both can be set as noted above but for
the Scales properties
Add extra traces to the graph by the graph object's menu Add Terminal ->
Data Input...
Likewise to add the mapping values pins to the Data -> Access Array ->
Set Mappings objects, click on the objects menu Add Terminal -> Data
Input then select Map From 1, do the same again to get the Map To 1
input pin.
If anything is not clear then keep asking!
Mike Watts
附件
有意义的
如果有什么不清楚,那就继续问!
迈克沃茨
以上来自于谷歌翻译
以下为原文
Notes:
open a dialog box
Data Input...
input pin.
Mike Watts
附件
举报
