感谢您的努力。
没有RF1&
RF 2适用。
如果没有这两个信号,就没有什么可以破坏接收器的稳定性。
你能得到2个射频发生器和合路器(耦合器)并将这两个信号输入两个频谱分析仪,看看当跨度设置为宽和窄时,9.1Hz RBW是否有任何差异?
我看到的边带是互调产物,所以你需要应用真实信号才能看到它们。
我在我们的实验室PXA中没有看到我们所有的MXA N9020A上的这种行为,但我确实有旧的PSA。
看起来它没有那种行为。
5MHz(可能比MXA扫描时间慢100倍)和1 KHz Span之间几乎没有差别。
RF1&读数
输入-20dB的RF2(内部衰减设置为16dB)显示在-130dBm左右。
我必须做的唯一调整是将默认的601点更改为1001点。
我的信念是,MXA可能有一些软件错误,它会强制信号为宽带路径,因此RBW设置为窄带。
此致,米雷克
以上来自于谷歌翻译
以下为原文
Appreciate for the effort.
There is not much telling without the RF1 & RF 2 apply. Without this two signals there is nothing to destabilize the receiver. Can you get some 2 RF generator and combiner (coupler) and feed the two signals into both spectrum analyzer and see if there is any difference when span is set wide and narrow with 9.1Hz RBW?
The sideband I see are intermodulation products so you need to apply real signal to see them.
I see this behavior on all our MXAs N9020A
I do not have in our lab PXA, however I do have the old PSA. Look like it do not have that behavior. Almost no difference between 5MHz (probably 100 time slower sweep time then on MXA) span and 1 KHz Span. The reading for with RF1 & RF2 at -20dB to input (internal attenuation set to16dB) show around -130dBm. The only adjustment I had to do was to change default 601 point to 1001 points.
My belief is that MXA might have some software bug where it force the signal for the wide band path even so the RBW is set to narrow band.
Regards,
Mirek
感谢您的努力。
没有RF1&
RF 2适用。
看起来它没有那种行为。
RF1&读数
此致,米雷克
以上来自于谷歌翻译
以下为原文
Regards,
Mirek
举报
