我们在几年内没有看到这个错误,因此我发现与此相关的所有CR可能与您的情况有关,也可能与您的情况无关。
此错误可能与设计中的重新定位实例有关。
更具体地说,它可能涉及TBUF(或BUFT)翻译。
检查您是否有这样的符号。
当你尝试13.1时,你只是重新运行地图或整个流程?
在13.1中重新运行NGDBuild可能会有所帮助。
如果设计最初的目标是V4之前的某些东西,它可能已成功重新定位到V4而不是V5,因为我们通常只支持重新定位一代。
如果是这种情况,那么该工具应该打印一个用户错误列出un而不是这个神秘的致命错误。
以上来自于谷歌翻译
以下为原文
We haven't seen this error in a few years so all the CRs I've found related to this may or may not be related to your case. This error likely has something to do with retargetting instances in the design. More specifically it may involve TBUF (or BUFT) translation. Check to see if you have such symbols.
When you tried 13.1 did you just rerun map or the entire flow? It's possible that rerunning NGDBuild in 13.1 would help.
If the design was originally targetted to something prior to V4, it's possible that it could have been retargetted to V4 successfully but not V5 since we typically only support retargetting for one generation. If that is the case then the tool should have printed a user error listing the un rather than this cryptic fatal error.
此错误可能与设计中的重新定位实例有关。
检查您是否有这样的符号。
以上来自于谷歌翻译
以下为原文
举报
