嗨,
我想将FF信号转移到特定切片中的FFY位置。
我尝试这样做时收到错误。
有可能做到这一点。
谢谢。
这是我的UCF线。
INST“CAM_IF_TP / CAM_INPUT_STG / CAM1 / CAM1_INPUT / Channel2Input / P1SYNCVALUEFOUNDii”LOC =“SLICE_X92Y36.FFY”;
和错误。
错误:MapLib:30 - CAM_IF_TP / CAM_INPUT_STG / CAM1 / CAM1_INPUT / Channel2Input / P1SYNCVALUEFOUNDii上的LOC约束SLICE_X92Y36.FFY无效:此架构中不允许对LOC约束进行扩展。
要绕过此错误,请设置环境变量“XIL_MAP_LOCWARN”。
以上来自于谷歌翻译
以下为原文
Hi,
I would like to locate a FF signal into the FFY loca
tion in a specific slice.
I receive a error when I try to do this. Is is possible to do this. Thank You.
Here is my UCF line.
INST "CAM_IF_TP/CAM_INPUT_STG/CAM1/CAM1_INPUT/Channel2Input/P1SYNCVALUEFOUNDii" LOC = "SLICE_X92Y36.FFY";
and the error.
ERROR:MapLib:30 - LOC constraint SLICE_X92Y36.FFY on
CAM_IF_TP/CAM_INPUT_STG/CAM1/CAM1_INPUT/Channel2Input/P1SYNCVALUEFOUNDii is
invalid: Extensions on LOC constraints are not allowed in this architecture.
To bypass this error set the environment variable 'XIL_MAP_LOCWARN'.
