继Citrix之后,他们告诉我们XD 7.6 FP3中修复了一些问题 - 如果使用XD7.6,可能需要在http://docs.citrix.com/en-us/xenapp-and-xendesktop/7-中查看这个问题。
6 / X-AD-什么新/功能包 - 3 - VDA-的桌面操作系统---固定issues.html
特别是Jason指出的无损指标问题可能是:
在启用了HDX 3D Pro的VDA上,无损指示器任务栏图标(对于LLIndicator.exe)可能无法指示无损状态,并且在右键单击时可能不响应。
[#LC2931]
VDA 7.6.300与7.7附带的VDA相同,因此升级到7.7还应包括7.6 FP3的修复程序
如果您遇到/怀疑它们,使用XD7.6绝对值得阅读其他问题 - #LC2931是您可以用来与Citrix支持讨论的错误号和参考。
我相信任何没有支持的Citrix客户都可以针对已知/已确认的问题提出机票,如果已知问题将退还该机票。
以上来自于谷歌翻译
以下为原文
Following up with Citrix, they advised us of some issues fixed in XD 7.6 FP3 - if using XD7.6 it's probably worth checking this in http://docs.citrix.com/en-us/xenapp-and-xendesktop/7-6/xad-whats-new/feature-pack-3--vda-for-desktop-os---fixed-issues.html
In particular the lossless indicator issue indicated by Jason is likely to be:
On VDAs with HDX 3D Pro enabled, the lossless indicator taskbar icon (for LLIndicator.exe) might fail to indicate the lossless state and might not respond when right-clicked.
[#LC2931]
VDA 7.6.300 is the same as the VDA that comes with 7.7 and so upgrading to 7.7 should also include the fix as per 7.6 FP3
It's definitely worth reading the other issues if using XD7.6 in case you encounter/suspect them - the #LC2931 is the bug number and reference that you can use to discuss with Citrix support. I believe any customer of Citrix without support can raise a ticket on a known/acknowledged issue that will be refunded if a known issue.
[#LC2931]
以上来自于谷歌翻译
以下为原文
[#LC2931]
举报
