英伟达
直播中
戚歆敦
7年用户 975经验值
私信 关注
[问答]
M60设置为graphicsmode但仍然显示计算
嗨,
我在Xenserver 7.2中有一个M60,我已经设置为gpugraphics(我已经对一些xenserver系统做了同样的事情,之前工作正常)。
但是,这个特殊的一个似乎停留在计算模式,如Nvidia Utility所示。
我正在做GPU Passthrough和windows 2016 LSTB,3D性能非常糟糕。
无法直接链接图像。
以上来自于谷歌翻译
以下为原文
Hi,
I have one M60 in Xenserver 7.2, I have set to gpugraphics (I have done same to a few xenserver system before which are working fine). However, this particular one seems to be stuck in compute mode, shown in Nvidia Utility. I'm doing GPU Passthrough and windows 2016 LSTB, and the 3D performance is very bad.
Unable to link image directly.
回帖(3)
李腈
2018-10-10 17:17:36
当gpumodeswitch显示图形模式时,你怎么知道M60仍处于计算模式?
您应该使用lspci命令检查虚拟机管理程序级别的图形模式。
以上来自于谷歌翻译
以下为原文
And how do you know that the M60 is still in compute mode when gpumodeswitch shows graphics mode?
You should use lspci command to check for graphics mode on hypervisor level.
举报
彭铮
2018-10-10 17:34:39
您是否尝试使用启动CD中的gpumodeswitch?
以上来自于谷歌翻译
以下为原文
Did you try to use the gpumodeswitch from the boot cd?
举报
吴秀英
2018-10-10 17:41:53
3d性能很慢,这就是我怀疑它处于计算模式的原因。
但经过一些测试后,我使用了来自公共nvidia网站的telsa驱动程序,这就引起了问题。
我换回了从nvidia portal获得的旧驱动程序,它的工作。
谢谢,圣诞快乐!
以上来自于谷歌翻译
以下为原文
the 3d performance was slow, that's why I suspected it is in compute mode. But after some testing, I used the telsa driver from public nvidia site, that is causing the problem. I switched back to older driver I gotten from nvidia portal, and its working. Thanks and merry christmas!
举报
更多回帖
