我们在Fat-Clients上有一个应用程序,由于OpenGL的要求,它附带了NVIDIA GeForce 9600/9800或Nvidia GeForce 285/295显卡。
我们现在要使用该应用程序使用“Virtual Desktop”。 我们有附带NVidia grid m60和ESX作为hypervisor的cisco ucs。 不幸的是,应用程序没有按预期工作,所以我想知道m60是否支持OpenGL。 感谢您的答复 以上来自于谷歌翻译 以下为原文 We have an application on Fat-Clients which has either NVIDIA GeForce 9600/ 9800 or Nvidia GeForce 285/ 295 graphic card attached because of OpenGL requirement. We are now to go "Virtual Desktop" with the application. We have cisco ucs with NVidia grid m60 attached, and ESX as hypervisor. Unfortunately the application is not working as expected, so I am wondering if m60 do support OpenGL at all. Thanks for your response |
10个回答
当然,我们支持使用GRID的OpenGL。
必须出现其他问题。 能否详细说明你的所作所为。 管理程序版本/ VDI解决方案/ NV驱动程序版本.... 以上来自于谷歌翻译 以下为原文 For sure we support OpenGL with GRID. The must be something else going wrong. Could you please give some more details what you did. Hypervisor version/VDI solution/NV driver version.... |
对不起,我刚刚回来,期待未来的电子邮件通知。
我必须对图形卡进行一些更正。 我们实际上有m6网卡,Fat-Clients上有Quadro 5000,Quadro FX4800或Quadro K5000。 以下是基础设施。 HW:cisco UCS B200 M4 图:NVidia M6-0B网格 管理程序:VMWare ESX 6.5 虚拟化:XenDesktop 7.13 VDA客户端:Windows 7(x64) NVidia驱动程序:NVIDIA图形驱动程序369.71,NVIDIA nView 148.03,NVIDIA WMI 2.27.3 刚收到徕卡的消息,虽然我们正在尝试通过ica(HDX)协议,但该功能需要“Quadro”驱动程序来处理正常的RDP 任何方向,你可以指出我进一步看。 谢谢 以上来自于谷歌翻译 以下为原文 Sorry that I'm just coming back, was expecting Email notification that didn't come. I have to bring in some corrections regarding the graphic cards. We actually have m6 Grid card, and on the Fat-Clients are either Quadro 5000, Quadro FX4800 or Quadro K5000. Below is the Infrastructure. HW: cisco UCS B200 M4 Graphic: NVidia M6-0B Grid Hypervisor: VMWare ESX 6.5 Virtualization: XenDesktop 7.13 VDA-Client: Windows 7 (x64) NVidia Driver: NVIDIA Graphics Driver 369.71, NVIDIA nView 148.03, NVIDIA WMI 2.27.3 Just got information from Leica that a "Quadro" driver would be required for that function to work on a normal RDP, though we are trying through ica (HDX) protocol Any direction you could point me to look further. Thanks |
你好
你还没有说出问题是什么? ......“未按预期工作”并未向我们提供任何帮助您的信息。 它是应用程序性能问题还是可视化问题? 查看上面提供的详细信息,您可能需要尝试将vGPU配置文件增加到512MB以上。 使用1Q,2Q,4Q或8Q配置文件然后查看会发生什么。 一旦您使用它,您就可以尝试不同的配置文件以获得最佳体验。 通常,我会完全忽略0B和0Q配置文件,因为它们不允许使用NVenc。 GRID驱动程序以与Quadro相同的方式通过ISV认证,因此这不是您的问题。 问候 以上来自于谷歌翻译 以下为原文 Hi You still haven't said what the problem is? ... "Not working as expected" doesn't give us any information to help you. Is it an application performance issue or is it a visualisation issue? Looking at the details you've provided above, you may want to try increasing the vGPU profile to more than 512MB. Use a 1Q, 2Q, 4Q or 8Q profile then see what happens. Once you have it working, you can then experiment with different profiles to get the best experience. Typically, I would just completely ignore the 0B and 0Q profiles, as they do not allow the use of NVenc. GRID drivers are ISV certified in the same way Quadro are, so this won't be your issue. Regards |
只有在您使用Citrix时才会这样吗?
RDP怎么样? 到目前为止你还尝试了什么? ... 以上来自于谷歌翻译 以下为原文 And is it only when you use Citrix? What about RDP? What else have you tried so far? ... |
我刚刚更改了配置文件配置并将机器分配给用户进行测试。
星期一,我必须带着结果回来。 RDP不起作用,因为一旦安装了NVIDIA驱动程序,我将无法访问该机器。 我相信通过RDP无法获得网卡功能。 如果我错了,请纠正 以上来自于谷歌翻译 以下为原文 I have just changed the Profile configuration and assigned the machines to the user for testing. I would have to come back on Monday with the results. RDP would not work, since I would not be able to access the Machine once NVIDIA driver is installed. And I believe the grid card functionalities would not be available through RDP. Please do correct if I'm wrong |
并非所有功能都可用,但您可以使用RDP进行连接和测试,GPU确实可以使用:-)
安装GRID驱动程序后,您无法使用ESXi控制台,也许这就是您的想法? 以上来自于谷歌翻译 以下为原文 Not all features are available, but you can connect and test with RDP and the GPU does get used :-) Once the GRID driver is installed, you can't use the ESXi console, maybe that's what you're thinking of? |
是的,我仍然可以通过RDP连接。
虽然我还没有得到用户的反馈,但我想知道它是否会因许可证而起作用。 我们实际上授权“Grid Virtual PC”,我认为它只涵盖“B”和“A”配置文件。 虽然0Q可能有效,但是当我们没有相应的许可证时,1Q-8Q会工作。 以上来自于谷歌翻译 以下为原文 Yes, I should still be able to connect through RDP. Though I am yet to get feedback from the users, but I am wondering if it would work due to licenses. We actually licensed "Grid Virtual PC", which I believe covers only "B" and "A" profiles. Though 0Q might work, but would 1Q - 8Q work when we do not have the appropriate licenses. |
得到了用户的反馈。
不幸的是,没有一个配置文件(1b,≈,1q,2q,4q,8q)工作。 与RDP相同。 以上来自于谷歌翻译 以下为原文 Got feedback from users. Unfortunately none of the profiles (1b, 0q, 1q, 2q, 4q, 8q) works. Same with RDP as well. |
嗨topokin,
仍然不确定问题是什么,但首先我建议检查你的VM是否正常工作。 请使用DXdiag,例如:http://realtech-vr.com/admin/glview来检查会话中的OGL功能。 之后您应该知道它是一般问题还是相关的应用程序。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi topokin, still not sure what the issue is but first of all I would recommend to check if your VM is working in general. Please use DXdiag and for example: http://realtech-vr.com/admin/glview to check the OGL capability within your session. Afterwards you should know if it is a general issue or application related. Regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3023 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3439 浏览 4 评论
GMT+8, 2024-10-19 06:05 , Processed in 0.967304 second(s), Total 93, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
