您应该将一个Aurora核心的共享逻辑配置为包含在核心中,并将第二个Aurora核心的共享逻辑配置在示例设计中。技术上,核心中具有共享逻辑的核心称为主,另一个称为从核
Master包含公共实例,并向slave提供gtrefclkout。请参阅http://www.xilinx.com/support/documentation/ip_documentation/aurora_64b66b/v10_0/pg074-aurora-64b66b.pdf的“共享逻辑”部分。
有关框图,请参见相同PG的图3-17,其中显示了主站和从站之间的互连。
---------------------------------------------请将帖子标记为
如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。
以上来自于谷歌翻译
以下为原文
You should configure one Aurora core's shared logic to be included within the core and the second Aurora core's shared logic to be included in the example design.
Technically, the core with shared logic in the core is called as master and the other is called as slave. Master contains common instantiation in it and provides the gtrefclkout to the slave.
Please refer to "Shared Logic" section of http://www.xilinx.com/support/documentation/ip_documentation/aurora_64b66b/v10_0/pg074-aurora-64b66b.pdf
Refer to Figure 3-17 of the same PG for block diagram showing the inter-connectivity between master and slave.-----------------------------------------------------------------------------------------------
Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue.
Give Kudos to a post which you think is helpful.
以上来自于谷歌翻译
以下为原文
举报
