英伟达
直播中
沈茜
7年用户 190经验值
私信 关注
[问答]
当与XenDesktop连接时,Autodesk正在选择错误的GPU
我们正在测试Win 10和XenDesktop 7.6,当我连接到VDA时,一切正常,您可以使用GPU-Z看到它使用vGPU配置文件(180Q),但是当我启动AutoCad Arch时。
2015年它选择“Citrix Display Only适配器”,结果是AutCad报告它没有使用硬件加速。
我有一个非常丑陋的解决方法,包括从HKCU regkey等删除NTFS权利,这不是我希望的正确方法......
有没有其他人看到这种行为,也许有一个解决方案让AC选择GPU而不是默认的驱动程序?
以上来自于谷歌翻译
以下为原文
We are testing Win 10 and XenDesktop 7.6 and when I connect to the VDA Everything works and you can see, using GPU-Z, that it uses the vGPU profile (180Q) but when I start AutoCad Arch. 2015 it picks the "Citrix Display Only adapter" and a consequence is that AutCad reports that it is not using hardware acceleration. I have a really ugly workaround which includes removing NTFS rights from a HKCU regkey etc and that can't be the correct way I hope...
Has anyone else seen this behaviour and perhaps have a solution to getting AC to pick the GPU instead of the default driver??
回帖(1)
李耘蝶
2018-9-25 18:21:47
看到这个帖子
https://gridforums.nvidia.com/default/topic/669/after-driver-update-some-autocad-lt-fails-to-use-hardware-driver/
以上来自于谷歌翻译
以下为原文
See this thread
举报
更多回帖
