你好
M10(主板)上有4个GPU。
使用1GB配置文件(您需要最小1GB配置文件以便使用NVenc),每个GPU可以获得8个VM和/或每个板可以获得32个VM(8x4 = 32)。
如果您使用2GB配置文件,每个主板将获得16个VM,因此您将无法为每个服务器支持20个用户。
除非您使用RDS,否则1GB是您唯一的选择。
至于最佳配置文件大小,这取决于应用程序,操作系统,有多少显示器及其分辨率。
需要考虑很多因素。
从1GB开始,看看是否足够,但如上所述,如果你更高,你将不会得到每个服务器20(并发)用户。
问候
以上来自于谷歌翻译
以下为原文
Hi
The M10 (the board) has 4 GPUs on it.
Using a 1GB Profile, (you'll need a 1GB Profile minimum so you can use NVenc) you can get 8 VMs per GPU and / or 32 VMs per board (8x4=32). If you use a 2GB Profile, you'll get 16 VMs per board, so you won't be able to support 20 users per server. 1GB is your only option, unless you use RDS.
As for the best Profile size, that depends on the applications, Operating System, how many monitors and their resolution. Lots of factors to consider. Start with 1GB and see if that's enough, but as said, if you go any higher, you won't get 20 (concurrent) users per server.
Regards
你好
M10(主板)上有4个GPU。
需要考虑很多因素。
问候
以上来自于谷歌翻译
以下为原文
Hi
Regards
举报
