嗨BJones,
谢谢你的重播。
我已经使用了eavluation许可证,我在那里做了每一步,如下所示:
功能版本计数可用到期时间
Quadro-Virtual-DWS 5.0 64 63 2018-01-01
但是我无法分配任何M60-4Q,M60-8Q,M6-4Q,M6-8Q配置文件,我读到的是为了拥有这个配置文件你必须运行3.0版本的somtheing(它不清楚)
症状/错误
当使用M60 / M6 GRID卡的4Q,8Q或Passthrough配置文件时,NVIDIA GRID驱动程序无法从许可证服务器签出许可证。
例如。
M60-4Q,M60-8Q,M6-4Q,M6-8Q型材。
原因
3.0代码发布之前的驱动程序需要4GB或更高版本的vWorkstation扩展许可证。
自2016年3月起,NVIDIA因许可变更而停止发运扩展许可。
如果客户/合作伙伴正在部署2016年3月之后获得的许可证,则他们将要求3.0或更高版本的驱动程序包使用大于2GB的配置文件。
解析度
更新到3.0驱动程序包或更高版本。
有关查找驱动程序的建议,请参见:http://nvidia.custhelp.com/app/answers/detail/a_id/4120
我有什么捆绑,我可以检查它?
Quadro-Virtual-DWS 5.0版是否足够好用?
提前致谢
来源http://nvidia.custhelp.com/app/answers/detail/a_id/4136/~/nvidia-grid-driver-is-unable-to-check-out-a-license-from-the-license-server
以上来自于谷歌翻译
以下为原文
Hi BJones,
thanks for the replay.
i am already using the eavluation license and i did every single step there, as you can see below:
Feature Version Count Available Expiry
but i cant assign any of M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles, what i read is that in order to have this profiles you have to run the 3.0 versionof somtheing (it was not clear)
Symptom/Error
NVIDIA GRID driver is unable to check out a license from the license server when using 4Q, 8Q or Passthrough profiles for the M60/M6 GRID cards. E.g. M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles.
Cause
Drivers prior to the 3.0 code release required a vWorkstation Extended license for 4GB or greater profiles.
Since March 2016 NVIDIA ceased to ship the Extended license as a result of the changes in licensing.
If customers / partners are deploying licenses acquired after March 2016 they will require the 3.0 or later driver bundle to use profiles larger than 2GB.
Resolution
Update to 3.0 driver bundle or later. Advice on finding the drivers is detailed here: http://nvidia.custhelp.com/app/answers/detail/a_id/4120
what bundle do i have and where i can check it ? is the Quadro-Virtual-DWS version 5.0 good enough for that ?
thanks in advance
source http://nvidia.custhelp.com/app/answers/detail/a_id/4136/~/nvidia-grid-driver-is-unable-to-check-out-a-license-from-the-license-server
嗨BJones,
谢谢你的重播。
功能版本计数可用到期时间
症状/错误
例如。
原因
解析度
更新到3.0驱动程序包或更高版本。
我有什么捆绑,我可以检查它?
提前致谢
以上来自于谷歌翻译
以下为原文
Hi BJones,
Symptom/Error
Cause
Resolution
thanks in advance
举报
