英伟达
直播中
李斌
8年用户 1471经验值
私信 关注
[问答]
我退出VDI时是否可以发布DWS GRID许可证?
使用Horizo​​n 7和GRID许可证5.0.0
如果我退出VDI,我希望它能够发布许可证,但事实并非如此。
从不再使用的VDI中释放许可证的最佳方法是什么?
谢谢,
-Ryan
以上来自于谷歌翻译
以下为原文
Using Horizon 7, and GRID license 5.0.0
If I log out of a VDI, I would expect it to release a license but it does not.  What is the best way to release a license from a VDI that is no longer in use?
Thanks,
-Ryan
回帖(4)
薛静斗
2018-9-18 16:29:52
嗨RBae,
这不是预期的行为。
你等了多长时间才发布许可证?
通常,VM关闭后需要10-15分钟才能释放许可证。
请用ESP创建支持票。
最好的祝福
西蒙
以上来自于谷歌翻译
以下为原文
Hi RBae,
this is not expected behavior. How long did you wait for the license to be released? In general it takes 10-15minutes to release the license after VM shutdown.
Please create a support ticket with ESP.
Best regards
Simon
举报
毛萃
2018-9-18 16:36:55
谢谢西蒙 - 会这样做。
现在已超过24小时,许可证尚未发布。
这只是我的一个许可证的问题。
如果我关闭其他VM,它会释放许可证。
在这种情况下我唯一做的就是我将带有许可证的VM转换为模板。
这就像模板有许可证,不会发布它。
-Ryan
以上来自于谷歌翻译
以下为原文
Thanks Simon - will do.
It's been well over 24 hours now with the license not being released.  This is a problem with just one of my licenses.  If I shut other VM's down, it does release the license.
The only thing that I did differently in this case was that I converted a VM with a license to a template.  It's like the template has the license and won't release it.
-Ryan
举报
孙勳努
2018-9-18 16:44:59
嗨RBae,
作为解决方法,您可以将VM租约时间(RegKey LicenseInterval)从7天默认值减少到例如1天,以确保在24小时后释放许可证。
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi RBae,
as workaround you could reduce the VM lease time (RegKey LicenseInterval) from the 7 days default value to for example 1 day to make sure the license is released after 24 hours.
Regards
Simon
举报
万菲
2018-9-18 16:50:33
西蒙非常感谢你的回答,我非常感激,因为我有同样的问题,但我想知道如果你不介意我是否可以问你一些其他的问题?
请?
再次感谢你!
以上来自于谷歌翻译
以下为原文
Simon thanks a lot for your answers, i really appreciate it a lot as i was having quite same questions, however i was wondering if i may ask you some other questions, if you don't mind? please? thank you again!
举报
更多回帖
