Microchip
直播中
林茜
7年用户 168经验值
私信 关注
[问答]
MCP2515数据手册中的振荡器起振定时器(OST)值出错怎么解决?
嗨,我用的是MCP2515 CAN控制器,在125kHz可以从20MHz的CRATSTAR波特率。在数据表DS2000 1801H页55和59,它写道,振荡器启动时间(OST)被定义为128toSC。因为我运行在20MHz,我期待唤醒时间是6.4。而不是那样,我经历了一个大于1ms后发送唤醒命令。(ReqOP=000在CuxTrl)是否可能是真正的ToSC值是128×TbAdRead,而不是128×Tosc????有人经历过同样的行为吗?当做,
以上来自于百度翻译
      以下为原文
    Hi,
I'm using a MCP2515 CAN controller at 125kHz CAN baud rate from a 20MHz cristal.
In Datasheet DS20001801H-pages 55 and 59, it's written that the Oscillator Start-up time (OST) is defined as 128Tosc. Since I'm running at 20MHz, i'm expecting that the wakeup time is 6.4µs. Instead of that, I'm experiencing a OST greater than 1ms after sending the wakeup command. (REQOP = 000 in CANCTRL)
Is it possible that the real Tosc value is 128*TBaudRate instead of 128*Tosc???
Anybody experiencing the same behavioral?
Regards,
   Attached Image(s)
回帖(5)
赵文娜
2018-9-17 17:02:37
我刚才看到一个有趣的行为比较WaKIF中断有关晶体振荡。它似乎有两个阶段的唤醒。功率晶体,但不振荡(ChanSTAT= 0x24睡眠+ WAKIF)晶体振荡(ChanSTAT=0x64侦听+WAKIF)正常模式(CANSTAT=0x00正常)也许128个ToSC只在唤醒的第二阶段有效吗????我希望这能帮助你帮助我!!!!当做,
以上来自于百度翻译
      以下为原文
    I just saw an interesting behavior when comparing the WAKIF interrupt related to the crystal oscillation. It seems to have two stage in Wake Up.
  • Power to crystal but not oscillating (CANSTAT = 0x24 Sleep + WAKIF)
  • Crystal oscillating (CANSTAT = 0x64 Listen Only + WAKIF)
  • Normal mode (CANSTAT = 0x00 Normal)
Maybe the 128 Tosc is only valid in the second stage of the wakeup???
I hope that will help you to help me!!!
Regards,
   Attached Image(s)
举报
赵文娜
2018-9-17 17:10:37
嗨,这是Microchip支持团队的第一个答案。我在等待更多的细节。---------------嗨,贾景晖,你好。你说得对。128ToSc适用于振荡器开始振荡的时刻。
以上来自于百度翻译
      以下为原文
    Hi,
Here is the first answer from the Microchip support team. I'm waiting for more details.
Hi Marc,
Good Day.
You're right. The 128Tosc applies at the moment the oscillator starts oscillating.
Regards,
MJ
Regards,
举报
蒋喜玲
2018-9-17 17:28:44
感谢您报告您的支持票的结果。对于一个20MHz的振荡器来说,毫秒似乎有点长——我本来期望几百微秒最大。什么连接到复位引脚?是否有一个可以解释延迟的RC复位电路?
以上来自于百度翻译
      以下为原文
    Thanks for reporting the results of your support ticket. A millisecond does seem a bit long for a 20MHz oscillator to get going - I would have expected a couple hundred microseconds max. What's connected to the Reset pin? Is there an RC reset circuit that could explain the delay?
举报
赵文娜
2018-9-17 17:36:06
谢谢你的回答,复位引脚直接连接到C的GPIO,当C准备就绪时它被强制高。在我的用例中,(总线活动唤醒中断),C已经准备好,模块永远不会复位(通过复位引脚或SPI复位命令EIDER)。
以上来自于百度翻译
      以下为原文
    Thank you mbrowning for your answer,
The reset pin is directly connected to a GPIO of the µC and it's forced high when the µC is ready.
In my use case, (Bus Activity Wake-up Interrupt), the µC is ready and the module is never reset (eider by the reset pin or by SPI reset command)
举报
更多回帖
