Microchip
直播中
陈桂平
8年用户 274经验值
私信 关注
[问答]
用一个数字锅代替模拟罐在电路不能正常工作
嗨,我想用一个数字锅代替模拟罐在这个电路。然而,它不能正常工作。有一些非常微小的声音波动,但仅此而已。我想知道需要做什么,或者为什么它不能像预期的那样工作,或者我如何解决问题。谢谢。
以上来自于百度翻译
      以下为原文
    Hi,
I would like to use a digital pot in place of the analog pot in this circuit. However, it does not work properly. There are some very tiny sound fluctuations but that is all. I wonder what needs to be done, or why its not working as expected, or how I can work out what the problem is.
thanks
   Attached Image(s)
回帖(9)
张娜
2018-9-14 16:05:32
嗯,应该工作,或多或少…
以上来自于百度翻译
      以下为原文
    Hmmm should work, more or less...
举报
陈发赫
2018-9-14 16:13:29
嗯,是的,在这种情况下更少。波动是WAH WAH电路(带宽滤波器改变)所期望的,但是FRQ范围变化非常小和短,更像是一个“THIP THIP”,而不是“WaaaaaWaaaaah”。可能与数字罐的电源有关吗????
以上来自于百度翻译
      以下为原文
    hmmm, yes less in this case. The fluctuations are what one would expect from a wah wah circuit (bandwidth filter changes), but the freq range change is very small and short, more like a "thip thip" than a "waaaaah waaaaaah".
perhaps something to do with the power supply for the digital pot???
举报
张娜
2018-9-14 16:30:59
是的,我或多或少地知道一个哇哇:即使我从来没有造过一个,我也考虑过在锅腿上的力量超过了它接受的东西,但是…既然有电容器就位,那就不应该发生了。
以上来自于百度翻译
      以下为原文
    Yep I know a wah-wah more or less :) even if I never built one.
I considered that thing about power at pot legs getting past what it accepts but... since there are capacitors in place then it should not happen.
举报
吴键洪
2018-9-14 16:39:48
锅是如何供电的?信号不能超出电源电平,所以电源必须与信号共享接地参考。
以上来自于百度翻译
      以下为原文
    How is the pot powered?
The signal must NOT go outside the power supply levels, so your power supply must share a ground reference with the signal.
举报
更多回帖
