你好,
请看下面的答案:
这是正常的吗?
不,这不是正常行为。
SOC是来自燃油表的最重要的预期信息。
2.在更新SOC值之前,STC3115是否需要经过最少次充电/放电循环?
不,第一个SOC在2秒后可用。
3.是否有任何触发事件开始更新SOC值?
不会。但是,当燃气表未正常运行时,通常会出现此问题。
这可能是因为引脚BATD浮动,避免了电量计启动电池监控。
解决硬件问题后,建议使用ST开源驱动程序正确初始化设备并运行它。
您可以在此处找到社区常见STC3115问题/常见问题解答:
https://github.com/st-sw/STC3115GenericDriver/wiki/STC3115-FAQ
它类似于STC3117。
问候
以上来自于谷歌翻译
以下为原文
Hello,
Please see answers below:
1. Is it normal?
No, this is not the normal behavior.
The SOC is the most important expected information from a fuel gauge.
2. Does the STC3115 need to go through a minimum number of charge/discharge cycles before it can update the SOC value?
No, the first SOC is available after 2s.
3. Is there any triggering events to start updating the SOC value?
No. But this issue usually arise when the gas gauge is not running properly.
It could be because the pin BATD is floating, avoiding the gas gauge to start the battery monitoring.
Once the hardware issue is resolved, it is then recommended to use ST open source driver to initialize properly the device and run it.
You can find a FAQ of common STC3115 questions/issue from the community here:
It is similar for STC3117.
Regards
你好,
请看下面的答案:
这是正常的吗?
不,这不是正常行为。
SOC是来自燃油表的最重要的预期信息。
不,第一个SOC在2秒后可用。
它类似于STC3117。
问候
以上来自于谷歌翻译
以下为原文
Hello,
1. Is it normal?
Regards
举报
