英伟达
直播中
徐冬蕾
8年用户 250经验值
私信 关注
[问答]
具有VMWare ESX的vDGA网格(无Horizon View)
我有一个Grid K1,它位于戴尔R720中。
我安装了ESXi 5.5,我想配置传递给VM。
我已经安装了.vib驱动程序
我已经在vCenter webui中配置了传递
我已将PCI设备连接到VM。
VM可以查看该卡并查询该卡,但显示将回退到本机Vmware驱动程序。
还有其他步骤吗?
我从nVidia看到的唯一部署指令都是指Horizo​​n View,但我只想将它们附加到独立的未经破解的VM上。
是否支持?
以上来自于谷歌翻译
以下为原文
I have a Grid K1 that's sitting in a Dell R720.
I have ESXi 5.5 installed and I'd like to configure pass through to the VMs.
I've installed the .vib drivers
I've configured the pass through in the vCenter webui
I've attached the PCI device to the VMs.
The VM can see the card and query the card, but display falls back to native Vmware driver.
Are there any more steps? The only deployment instructions I see from nVidia all refer to Horizon View, but I just want to attach these to stand alone unbrokered VMs. Is it supported?
回帖(19)
张玉英
2018-9-6 10:28:59
你好notrobb,
请按照http://www.vmware.com/files/pdf/techpaper/vmware-horizo​​n-view-graphics-acceleration-deployment.pdf上的安装说明进行操作,并注意vDGA(GPU Passthrough)不需要振动驱动程序。
vSGA和vGPU有振动驱动器,但vDGA不需要振动驱动器
如果有帮助,请告诉我。
谢谢,
Erik Bohnhorst
NVIDIA GRID高级解决方案架构师
以上来自于谷歌翻译
以下为原文
Hello notrobb,
please follow the installation instructions at http://www.vmware.com/files/pdf/techpaper/vmware-horizon-view-graphics-acceleration-deployment.pdf and note that no vib driver is required for vDGA (GPU Passthrough). There is a vib driver for vSGA and vGPU but none is necessary for vDGA
Let me know if that helps.
Thanks,
Erik Bohnhorst
NVIDIA GRID Senior Solution Architect
举报
王建军
2018-9-6 10:35:22
嗨埃里克,
感谢您的回复。
我们安装了.vib驱动程序,因为有些测试人员想要在vSGA,vDGA和vGPU之间来回切换。
我应该删除它们以使vDGA工作吗?
另外,为了确认,如果我不使用Horizo​​n View,Horizo​​n View文档应该可以正常工作吗?
以上来自于谷歌翻译
以下为原文
Hi Eric,
Thanks for your reply. We installed the .vib drivers because some testers want to switch back and forth between vSGA, vDGA and vGPU. Should I remove them for vDGA to work?
Also, just to confirm, the Horizon View docs should work if I'm not using Horizon View?
举报
桂莅鑫
2018-9-6 10:45:22
嗨notrobb,
你是什​​么意思“我没有使用Horizo​​n View”?
请从ESXi卸载所有vib文件。
一旦vDGA工作,我们也可以运行它们。
谢谢,
埃里克
以上来自于谷歌翻译
以下为原文
Hi notrobb,
what do you mean by "I'm not using Horizon View"?
Please uninstall all vib files off of ESXi. Once vDGA works, we can get those running as well.
Thanks,
Erik
举报
秦婷婷
2018-9-6 10:55:53
嗨埃里克,
我的意思是我没有在VM上安装VMWare Horizo​​n View Agent,而我没有将它们连接到Horizo​​n View Server。
我只是在ESXi上运行一个VM,我希望使用vDGA passthrough。
现在我们通过控制台连接,然后我们将转向其他方式。
这支持吗?
关于使用vDGA和Passthrough的所有文档似乎都明确谈到了使用VMWare Horizo​​n View(我们不是这样)。
我将卸载.vibs,看看是否有帮助。
以上来自于谷歌翻译
以下为原文
Hi Eric,
I mean that I am not installing the VMWare Horizon View Agent on the VM and I am not connecting them to a Horizon View Server. I simply have a VM running on ESXi and am hoping to use vDGA passthrough.
For now we're connecting via the console, and then we'll move on to other means. Is this supported? All the documentation about using vDGA and Passthrough seem to explicitly talk about using VMWare Horizon View (which we are not).
I'll uninstall the .vibs and see if that helps.
举报
更多回帖
