你好
详细的GRID许可信息可从第3页开始提供http://images.nvidia.com/content/pdf/grid/guides/GRID-Licensing-Guide.pdf
vApp(“A”配置文件)=当您通过Citrix XenApp等部署应用程序时
vPC(“B”配置文件)=适用于部署桌面操作系统(Horizon / XenDesktop)的情况,如Windows 10,理想情况下需要GPU **
vWS(“Q”配置文件)=对于1或更高的4K分辨率,需要CUDA的应用程序。
这与Quadro系列的驱动程序基本相同,因此通过了ISV认证。
**注意:如果您的应用程序需要CUDA,您必须拥有vWS许可证(Q Profile),即使它只是正在交付的应用程序。
因此,您无法使用“B”配置文件来提供单个CUDA应用程序。
正如文件所述,许可证包括较低版本。
因此,vWS同时包含vPC和vApp许可证。
每个许可证版本在分辨率,帧缓冲区,支持的监视器数量以及明显的功能方面都有局限性,因此请确保您了解资源需求以及计划在购买之前如何部署它。
我希望这是有道理的。
以上来自于谷歌翻译
以下为原文
Hi
Detailed GRID Licensing information is available here from page 3 onwards http://images.nvidia.com/content/pdf/grid/guides/GRID-Licensing-Guide.pdf
vApps ("A" Profile) = For when you're deploying just the application through something like Citrix XenApp **
vPC ("B" Profile) = For when you're deploying a desktop operating system (Horizon / XenDesktop) with something like Windows 10 that ideally needs a GPU **
vWS ("Q" Profile) = For 4K resolutions of 1 or more, applications that require CUDA. This is basically the same driver as the Quadro line so is ISV certified.
** Note: If your applications require CUDA, you must have a vWS license (Q Profile), even if it is just the application being delivered. So you can't use a "B" profile to deliver a single CUDA application.
As the document states, the licenses are inclusive of lower editions. So a vWS has both the vPC and vApps license included.
Each license edition has limitations in terms of resolution, frame buffer, the amount of monitors supported and obviously functionality, so ensure you understand your resource requirements, and how you plan to deploy it before purchasing.
I hope that makes sense.
你好
正如文件所述,许可证包括较低版本。
我希望这是有道理的。
以上来自于谷歌翻译
以下为原文
Hi
举报
